PCV Valve - JeepForum.com
post #1 of 2 Old 09-24-2001, 11:14 PM Thread Starter
mkenn18673
PCV Valve
I'm new to the group. Bought a 1990 Wrangler in August. My question is: I have a 4 cylinder 2.5L and was wondering if the PCV valve is supposed to be in the front or the back. Right now it's coming from the air filter. I couldn't find any pictures of the 1990 4 cylinder engine. Would like to know this before I get called up for my Army National Guard duty. Any help would be much appreciated. Thank you in advance!
mkenn18673 is offline
post #2 of 2 Old 10-16-2001, 10:15 AM
glm 87 wrangler
looked it up in the book and found your pcv valve is in behind were you add oil,if there is a hole there than your pcv valve is gone but if there something sticking out than thats it.When you pull it out shack it.If it rattels than your ok just wipe it off real good and blow it out.if it does not rattle than replace it.You can replace it any way if you would like, cheap..Get a haynes manual,it your bible for the jeep,bet 9.00 to 15.00 you will spend.Good luck with your guard duty..and take care..
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
Lifter tick, valve chatter, sticky valve..... brtt485 YJ Wrangler Technical Forum 28 09-29-2012 12:07 AM
Broke elbow on pcv valve on front of valve cover... 99JeepWrangler TJ Wrangler Technical Forum 12 01-01-2009 02:17 PM
EGR valve help cableguy01960 YJ Wrangler Technical Forum 1 10-28-2008 10:20 PM
93, 4 Cyl, YJ Valve Cover Leaking = New Valve Cover?! Jim93YJ YJ Wrangler Technical Forum 10 09-12-2007 04:33 PM
pcv valve? genakab TJ Wrangler Technical Forum 6 02-24-2006 08:05 AM
