PCV valve - JeepForum.com
post #1 of 2 Old 08-20-2011, 12:27 PM Thread Starter
streetriots
PCV valve
I believe that this is causing oil to blow out through my dipstick tube. But when I go to buy a new one the auto parts stores do not have one that will fit in my valve cover. The PCV valve that they try to sell me for my Jeep has a shroud that hits on part of the valve cover when trying to insert it. Has anyone else had this problem? If so how did you remedy it?
Thanks
streetriots is offline
post #2 of 2 Old 08-20-2011, 01:53 PM
oldtime_ironman
One thing I've learned (the hard way) is that jeeps are kinda fussy about the lines to and from the valve cover. Mine used to blow a quart of oil every 2 weeks till I fixed it. The thing is to keep the lines absolutely clean on the inside, and make sure they are very tight. I ended up replacing all the rubber lines on mine with new ones, its cheap and easy. That fixed it because the thing won't breathe the crankcase properly unless it has a pretty strong vacuum. My lines were old and stiff and loose, the new ones are new and tight.
IIRC I used 5/16ths vacuum hose on the small front line - that fixed it, only 89 cents a foot.
Try NAPA for your parts, I've had the best luck with them. They seem quite knowledgable and have everything. If your PCV rattles when you shake it, its still good. Sometimes you can clean them out by soaking in gas.
Hope that helps!
oldtime_ironman is offline
Lifter tick, valve chatter, sticky valve..... brtt485 YJ Wrangler Technical Forum 28 09-29-2012 12:07 AM
Help Removing PCV Valve from Valve Cover webdave JK Wrangler Technical Forum 7 04-30-2011 06:21 PM
PCV Valve ??? Newk76 YJ Wrangler Technical Forum 9 04-22-2011 02:43 PM
Broke elbow on pcv valve on front of valve cover... 99JeepWrangler TJ Wrangler Technical Forum 12 01-01-2009 02:17 PM
93, 4 Cyl, YJ Valve Cover Leaking = New Valve Cover?! Jim93YJ YJ Wrangler Technical Forum 10 09-12-2007 04:33 PM
