pcv valve? - Page 2 - JeepForum.com
post #16 of 32 Old 06-27-2011, 06:55 PM
1SASjeepster
Guys, I am not sure what you are talking about. There is no PCV on a 2.5 engine. None. On the front of the valve cover (driver's side) is a small brass fitting with a narrow hole. This orifice acts as the PCV valve. It plugs into the vacuum system leading to the intake manifold. It is in the second photo by Andywear. All of the filters and PCV valves in the other photos were "add ons" by previous owners (or current owners.) This orifice works the same way the PCV valve works on other vehicles. It is narrow because that is all that is needed to this particular job. Good luck with it. Take care.
1SASjeepster is offline
post #17 of 32 Old 06-27-2011, 07:33 PM Thread Starter
JMAC90YJ
JMAC90YJ's Avatar
ok, My manafold shows the firing order cast into it and also XJ. The first photo id the filter thing and you can see where it leads, the second one shows the pipe that the PCV was connected to and it goes into the carb on the bottom. If the manafold is actually from an XJ how do I find out what the heck engine I have? The only hose that goes to the air box is a small rubber hose and it goes to the top of carb cover.
JMAC90YJ is offline
post #18 of 32 Old 06-27-2011, 10:45 PM
baritone_mike
The 2.5 is not carbed do you mean the throttle body
My 2.5 is the exact same and from what I can tell it is the stock motor. My manafold says XJ on it and has the firing order stamped into it. My 2.5 also has the PCV valve and the filter in the back. They changed the 2.5 to multi-port fuel injection in 1991 (check the FAQ) so that is why the guy above you does not have a PCV valve.
The reason I could not find the filter at an autoparts store is because I wanted the stock one that looked the same and had the hose to hook up to it.
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
baritone_mike is offline
post #19 of 32 Old 06-28-2011, 05:12 AM Thread Starter
JMAC90YJ
JMAC90YJ's Avatar
Thanks,, Makes me feel better. I thought I had a bass-turd.
JMAC90YJ is offline
post #20 of 32 Old 06-28-2011, 06:49 AM
Andywear
Thanks guys.
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #21 of 32 Old 06-28-2011, 08:20 AM Thread Starter
JMAC90YJ
JMAC90YJ's Avatar
Back to air filter box, The little hose on the top left of the box goes to the TB cover and the larger hose just hangs down, I think it is a drain hose? and there is a little hose comming off the back of the TB cover that just hangs down that the PO must have put a plug into.
JMAC90YJ is offline
post #22 of 32 Old 06-28-2011, 08:30 AM
Andywear
Jmac- I want that jack bracket!!!!!
Andywear is offline
post #23 of 32 Old 06-28-2011, 08:37 AM Thread Starter
JMAC90YJ
JMAC90YJ's Avatar
It's never been used or removed that I know of.
If I ever get rid of it, It's yours!
JMAC90YJ is offline
post #24 of 32 Old 06-28-2011, 09:10 AM
Andywear
Now that you have helped me time to poke fun.
Who shipped that battery to you I dont believe it was properly received in and I dont think that wire covering is going to hold up/be sturdy enough for the front grill. jus'sayin
Andywear is offline
post #25 of 32 Old 06-28-2011, 09:46 AM Thread Starter
JMAC90YJ
JMAC90YJ's Avatar
I put the p/s envelope there to keep a copy of my receipt for warranty! wire cover is holding my fog light wires out of the way, so I put some on the other side also. Thought it looked snazzy.
JMAC90YJ is offline
post #26 of 32 Old 06-28-2011, 12:37 PM
cvdenson
I have an 89, 2.5L TBI just like yours. You'll notice on the back of the TB cover, there is a two-pronged male end plug. There are two hose (female end) that plug into this and are routed to the back of the air filter assembly. They don't just hang.
89 YJ Wrangler 2.5L, all stock for now.
cvdenson is offline
post #27 of 32 Old 06-28-2011, 03:27 PM Thread Starter
JMAC90YJ
JMAC90YJ's Avatar
I will take a couple more photos later, I only had one little hose coming out of the box, looks like I have some more investigating to do. This thing will run like a champ when I get this stuff fixed.
I called my dealership and they could not ID the air filter on the rear of valve cover.
JMAC90YJ is offline
post #28 of 32 Old 06-28-2011, 05:52 PM Thread Starter
JMAC90YJ
JMAC90YJ's Avatar
The first photo shows the vacuum hose with plug and other one shows air filter box
JMAC90YJ is offline
post #29 of 32 Old 06-28-2011, 08:56 PM
baritone_mike
It was called a crank case breather element. The parts guy should have a book with a picture of the 2.5 in it if you drive down there with the part. (or at least my dealership does)
post #30 of 32 Old 06-28-2011, 09:06 PM Thread Starter
JMAC90YJ
JMAC90YJ's Avatar
I actually took the Jeep to the dealership after work.It is part of the emission controls part# 53002466. Tomorrow I will scan the drawing of the emission controls, it may help someone else,
JMAC90YJ is offline
Lifter tick, valve chatter, sticky valve..... brtt485 YJ Wrangler Technical Forum 28 09-29-2012 12:07 AM
Help Removing PCV Valve from Valve Cover webdave JK Wrangler Technical Forum 7 04-30-2011 06:21 PM
Broke elbow on pcv valve on front of valve cover... 99JeepWrangler TJ Wrangler Technical Forum 12 01-01-2009 02:17 PM
CTO Valve Hiker0550 YJ Wrangler Technical Forum 1 05-16-2008 06:54 PM
93, 4 Cyl, YJ Valve Cover Leaking = New Valve Cover?! Jim93YJ YJ Wrangler Technical Forum 10 09-12-2007 04:33 PM
