PCV/CCB 2.5l Question - JeepForum.com
post #1 of 5 Old 05-22-2012, 04:56 PM Thread Starter
Jeeper48
I think i need a new what i thought was a PCV valve but after a little bit of research I think its called a CCB valve. I have found a replacement but it says it will only fit a 1994 and up but my jeep is a 1993. Will this fit or do you know where I can order the part I need?
Thank-you
Mitchell
Jeeper48 is offline
post #2 of 5 Old 05-23-2012, 10:50 AM
Que89YJ
It should fit The breather tube is just an piece of hose.
Que89YJ is offline
post #3 of 5 Old 05-23-2012, 10:54 AM
Andywear
IIRC, 2.5's do not have a valve as the 4.0's do.
Do you have oil blowing into the air filter area?
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #4 of 5 Old 05-23-2012, 09:43 PM Thread Starter
Jeeper48
Andywear yes I did have some oil in my air filter.
Jeeper48 is offline
post #5 of 5 Old 05-24-2012, 07:30 AM
Andywear
your not alone.
couple thing can be done to help but it seams the route cause is worn out engine.
What I did was..
Make sure none of the hoses have cracks in them. this will make sure you have proper vacume.
Take off and clean any connections that might be blocked up with debris. (old oil, dirt, grim)
Pull valve cover and clean and pull baffels out and clean them as well.(baffles are held inside cover by 3-4 small screws.)
My thread that many helped on is here:
http://www.jeepforum.com/forum/f12/w...-here-1318801/
There were some ideas that were provided that I did not do that may help you.
Andywear is offline
Lift/Tires question and Cleaning soft top & engine question Bryan_16 TJ Wrangler Technical Forum 16 05-19-2012 03:25 PM
Front sway bar question + bonus disco question WranglerTom TJ Wrangler Technical Forum 7 12-02-2011 08:13 AM
drag link question, and also tyre sizing question snowmanbud TJ Wrangler Technical Forum 3 11-21-2010 07:38 AM
1988 carberator question and wiring (general) question prljeep YJ Wrangler Technical Forum 15 05-08-2009 11:50 AM
Tire question(noob question but just a quick answer needed) 07SilverX JK Wrangler Technical Forum 3 12-25-2007 03:35 PM
