Passenger side axle shaft replacement options,not tj - Page 2 - JeepForum.com
post #16 of 22 Old 02-10-2013, 03:56 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I meant the shape. Got a picture?
Luck Favours The Prepared
Anticanman is offline
post #17 of 22 Old 02-10-2013, 07:14 AM
TSEJEEPERS
4WD has stock shafts, they all use the larger 297x Ujoint.
Pretty sure the one you have in the picture is either one of these or one from a 95 YJ.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #18 of 22 Old 02-10-2013, 07:19 AM
mrdeath2000
Might be a d44 or maybe by upgraded shafts the previous owner swapped the 95 axles already with the 290 joints instead of the stock 260's.
You could... Piece together some Frankenstein azz axles with chromo driver axle and chromo passenger stub only, in theory... Haven't actually seen it done.
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
post #19 of 22 Old 02-10-2013, 07:45 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I would put my bet on a Dana 44 with disconnect
post #20 of 22 Old 02-10-2013, 09:20 AM Thread Starter
grog
Here's a pic of the cover
grog is offline
post #21 of 22 Old 02-10-2013, 11:01 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Yep, d30.
One shaft is the tiny 260 joints, the other you had is 297/760x joints.
Stock offerings
ratmonkey is offline
post #22 of 22 Old 02-10-2013, 11:58 AM
kirksjeep
Why no TJ shafts? With the larger u joint they are stronger, and now says much easier to find replacements. 95 YJs used the larger u joint, but they are pretty hard to find. If you call a wrecking yard and ask for a XJ shaft out of 96+ is will be the same as a TJ but half the price.
1992 YJ Sahara- 4.5" RE XD, 1" BL, 1" MML, 35" BFG MT, 8.8 w/Aussie, D30 w/Ten Factory shafts/ Aussie, 4:10 gears, Soild Diff Covers, SYE, CV Drive shaft, OBA, Flowmaster Super 44,, Custom head pipe, Super Chip, Boared out TB, Rock It Intake , Goferit Tie Rod Flip, 99+ intake manifold/Steering pump, custom front/rear bumpers,Hand Throttle, Hurst Shifter, Smitty Built sliders , 6" TJ flairs, Kilby belly up skid, Quadratech 9K winch, ZJ PS cooler. 01 XJ Sport-2" lift, 31x10.50 MT/ 02 Liberty 2" Lift
kirksjeep is offline
