Passenger side axle shaft replacement options,not tj - JeepForum.com
post #1 of 22 Old 02-09-2013, 12:00 PM Thread Starter
grog
I broke the u joint and the ends of both shafts,and don't want to put in tj shafts, because I'm selling the jeep and don't want to deal with the extra work. I know it's not much extra work. It had aftermarket shafts in it when I bought it but I don't know what kind. Does anybody know where I can get just the axle from the vac disco out? Not stock ones?
grog is offline
post #2 of 22 Old 02-09-2013, 02:26 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
why do you need a whole shaft if you only broke the joint?
ratmonkey is offline
post #3 of 22 Old 02-09-2013, 02:32 PM Thread Starter
grog
Both axles have damaged yokes
grog is offline
post #4 of 22 Old 02-09-2013, 02:34 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You need stock shafts? Where in nor cal are you?
Luck Favours The Prepared
Anticanman is offline
post #5 of 22 Old 02-09-2013, 02:59 PM Thread Starter
grog
Redding ca. I don't really want stock. Looking for something better. Do you have a stock one cheep? I've got 35s and stock ones wouldn't last.
grog is offline
post #6 of 22 Old 02-09-2013, 03:57 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You either get stock Yj shafts, one piece TJ shafts which require the seal installed or strong chromoly one piece axles.
If you want something stronger in a two piece you would have to source a set of '95 Yj shafts.
Take your pick.
post #7 of 22 Old 02-09-2013, 04:40 PM Thread Starter
grog
I've tried most manufactures and they aren't offering anything with the vac disco.
grog is offline
post #8 of 22 Old 02-09-2013, 05:26 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
that's what he said.
in reference to the 95 set, he meant go get some from salvage.
post #9 of 22 Old 02-09-2013, 06:33 PM Thread Starter
grog
Ya if you read the post I don't want stock shafts. Thx for the smart *** comment rat monkey.
grog is offline
post #10 of 22 Old 02-10-2013, 12:29 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Somebody filled your ears with a bag of dung & you listened.
You were running stock stuff & didn't know it.
Nobody's being a smarty pants, except you.
You haven't found aftermarket two piece axle shafts that are better than the stock ones, because they don't exist
Leave the attitude at the door. This is your only warning.
Joe Dillard is online now
post #11 of 22 Old 02-10-2013, 01:25 AM Thread Starter
grog
Does this look like a stock shaft?
grog is offline
post #12 of 22 Old 02-10-2013, 01:30 AM Thread Starter
grog
So where did this magical shaft come from?
I replaced it with a stock shaft from another axle a friend had laying around, and it was no where near the size of this one and had smaller u joints.
grog is offline
post #13 of 22 Old 02-10-2013, 01:33 AM Thread Starter
grog
I've been warned? I asked for options that weren't stock. Here is one. I just don't know who made it. Do you? No cause they don't make it,right?
grog is offline
post #14 of 22 Old 02-10-2013, 02:19 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Right. What does your diff cover look like?
post #15 of 22 Old 02-10-2013, 03:08 AM Thread Starter
grog
Like a ox locker.
grog is offline
