Passenger side axle leak. - JeepForum.com
post #1 of 4 Old 07-28-2010, 09:07 PM Thread Starter
grog
Put new outer axle on my 93 yj and now it leaks. Guy at the auto parts store said that I have to remove the axles and the locker and replace the seals inside the pumpkin. Isn't there a seal the vac disconnect area? The guy at the parts store said "the one there doesn't stop oil, it just stops dirt". True or not? Doesn't the vac disco have to be lubed to slide?
grog is offline
post #2 of 4 Old 07-28-2010, 09:21 PM
jbolty
jbolty's Avatar
He is probably thinking of the plastic disk on the far outboard end of the axle tube that does nothing
Unless you swapped to TJ shafts you have a seal on the outboard side of the diconnect housing, for the pass side. The drivers side seal is inside the pumpkin.
jbolty is offline
post #3 of 4 Old 07-28-2010, 09:22 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
On the passenger side of a YJ's HPD30, the axle seal is located on the outer side of the vacuum disc housing.
Yes, the vacuum disco gets it's lubrication from the diff fluid.
The parts guy is mistaken. He's probably thinking about other types of D30 housings which do have the passenger side axle seal internal to the housing.
Joe Dillard is offline
post #4 of 4 Old 07-29-2010, 01:48 AM Thread Starter
grog
Thx for info. I thought he didn't know what he was talking about.
grog is offline
Dana 35 axle Leak, Driver side rear side of the axle Mikey1234 YJ Wrangler Technical Forum 4 04-29-2010 11:08 AM
Passenger side leak?? mpo JK Wrangler Technical Forum 1 12-17-2008 05:58 PM
Leak in the passenger side baseballcaz TJ Wrangler Technical Forum 2 12-02-2008 05:20 PM
Passenger Side leak, Air conditioner?? TheyStoleMyShoe TJ Wrangler Technical Forum 2 06-11-2004 06:55 AM
Passenger Side Leak?? Dirky TJ Wrangler Technical Forum 2 08-06-2003 12:02 AM
