Quantcast Passanger Front Brake Smoking - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Passanger Front Brake Smoking
Old 02-16-2009, 01:41 PM   #1
RedlineRyan
Help my passanger front brake is smoking
it seems like it is locked up
if my ebrake was stuck wouldnt all the brakes lockup
what other possibilties?
RedlineRyan is offline   Reply With Quote
Old 02-16-2009, 01:48 PM   #2
Chris
I do stuff
Chris's Avatar
It could be a frozen caliper. and your ebrake would lock up the rear brakes only.
Got any plumbing questions? Are you a plumber? Need another general discussion to hang out in?
Check out plumbingforums.com
Need another Wrangler forum?
Check out wranglerboard.com
Chris is offline   Reply With Quote
Old 02-16-2009, 01:51 PM   #3
RedlineRyan
do i need to replace the caliper
i probably torched the pad
Old 02-16-2009, 01:59 PM   #4
MLJeeper
MLJeeper's Avatar
Stuck caliper, replace it and the pads.
Your limited slip differential sucks.
MLJeeper is offline   Reply With Quote
Old 02-16-2009, 02:10 PM   #5
jsahara24
1995 XJ Cherokee
i would get new rotors as well.....
95' Jeep Cherokee Sport
03' Subaru Forester X
jsahara24 is offline   Reply With Quote
Old 02-16-2009, 02:20 PM   #6
RedlineRyan
yep cailper is stuck i just removed my wheel
whats the importance of replacing the rotor
Old 02-16-2009, 02:36 PM   #7
alc60560
It got over heated by the stuck calaper. It is probably warped.
alc60560 is offline   Reply With Quote
Old 02-16-2009, 02:48 PM   #8
RedlineRyan
ok im thinking of doing the brakes on both sides
so ill buy 2 pads
1 cailper
1 rotor
that sound like the way to go?
Old 02-16-2009, 02:53 PM   #9
alc60560
Rotors arn't that much $30 It depends if you can aford it.
Old 02-16-2009, 02:59 PM   #10
RedlineRyan
i looked and 2 rotors 2 pads 2 cailpers is 103 bucks i can do that so i might as well replace everything
Old 02-16-2009, 03:00 PM   #11
denalione
I've always heard that you should replace both calipers at the same time. Maybe people were just trying to sell me something. They are pretty cheap if I recall correctly.
denalione is offline   Reply With Quote
Old 02-16-2009, 03:03 PM   #12
MLJeeper
MLJeeper's Avatar
Its never a bad idea, but its not always feasible. Stands to reason that if one side is beat, the others not far behind. But you dont "have" to.
Old 02-16-2009, 03:25 PM   #13
giggityjeeper
DO BOTH SIDES..........its cheap and easy, just do it now or in a couple weeks....
Started with some rust repairs ended in a SOA...
http://www.jeepforum.com/forum/f12/how-make-big-hole-your-jeep-1050879/
family roll bar swap/upgrade..
http://www.jeepforum.com/forum/f12/family-bar-swap-upgrade-1054753/
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline   Reply With Quote
Old 02-16-2009, 03:25 PM   #14
jsahara24
1995 XJ Cherokee
For that price i would definitely do both sides...
Old 03-03-2009, 09:30 AM   #15
RedlineRyan
it actually ended up being a rock lodged behind the pad
Glock Forum
