Part # for axle seal on vacuum disco to one piece shaft needed - JeepForum.com
post #1 of 6 Old 11-02-2008, 08:58 PM Thread Starter
willness33
Since I've never actually had to do this conversion, and the search leads me around in circles, does anyone know for a fact the part # for the axle seal that's needed? TIA
willness33 is offline
post #2 of 6 Old 11-02-2008, 09:02 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
This is one that will work. There are several PN's that will work.
Joe Dillard is offline
post #3 of 6 Old 11-02-2008, 09:05 PM
Joe Dillard
Here's another reference to PN's as well from my friend Stu Olson's website.
Different PN's, but they work too.
http://www.stu-offroad.com/axle/yjd3...jconvert-1.htm
post #4 of 6 Old 11-02-2008, 09:13 PM Thread Starter
willness33
Thanks a ton!!!!! I was going to check Stu's, but it's in a category that gets blocked here at work.
post #5 of 6 Old 11-02-2008, 09:19 PM
Joe Dillard
In that case....here's a cut & paste from Stu's website where there's a nice write-up on swapping TJ shafts into a YJ. These first PN's are from the Warn hub conversion kit.
Inner seal - 37897
Outer seal - 60006
Block off plate - 39147
Note from Stu: I pulled these part numbers off of a reliable forum, however, I've not verified them:
Inner seal - Chicago Rawhide CR11343
Outer seal - Spicer 46470
post #6 of 6 Old 11-02-2008, 09:25 PM Thread Starter
willness33
Again, much thanks!
How to: Vacuum Disco Elimination, Axle Tube Sleeve Fix, ubolt eliminator - 56K beware Joe Dillard YJ Wrangler Technical Forum 48 02-17-2016 04:39 AM
D44 axle shaft... part #'s needed thejafe TJ Wrangler Technical Forum 1 02-03-2009 08:49 PM
dana 44 wagonner axle swap, vacuum disco joe's_yj YJ Wrangler Technical Forum 2 06-30-2008 01:47 PM
Is there a 1 piece right axle shaft for d30? need4spd YJ Wrangler Technical Forum 10 09-16-2007 01:19 PM
Front axle vacuum line help (vacuum help part 2) mrmustang YJ Wrangler Technical Forum 13 02-13-2007 06:26 PM
