Parking it for winter - JeepForum.com
post #1 of 12 Old 11-03-2011, 06:42 AM Thread Starter
CJ51973
CJ51973's Avatar
I am parking the Jeep and dropping the insurance for the winter. It will sit behind the shed on dirt. Do you think it would be worth putting a piece of wood or something under each wheel as a barrier between tires and dirt? I will move it once a month just to keep stuff moving. Just not wanting to mess my new tires up.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #2 of 12 Old 11-03-2011, 06:45 AM
jsawduste
2006 YJ Wrangler
Better to cover the tires up with a UV blocking tarp or something to block the sun.
UV rays will eat your tires.
jsawduste is offline
post #3 of 12 Old 11-03-2011, 07:05 AM
oldtime_ironman
^^^ X2 on UV potection for it - use a tarp. Also according to Hot Rod magazine, its better if you can take the weight off the tires and store it on jack stands under the frame. Let the tires down to like 10 PSI during storage on stands. It tends to prevent cracking.
You might have to change the fluids when you run it again, since there's no way for it to lose the condensation unless its run good and hot for a while. You end up with 3 different kinds of milkshake. The engine might be OK if you start it for an hour and let it idle every week, but the tranny and axles will never warm up enough.
oldtime_ironman is offline
post #4 of 12 Old 11-03-2011, 07:26 AM
brentd711
I dropped my (liability only) insurance while I'm rebuilding the Jeep and got a policy change notice that my premium had dropped by $2.
brentd711 is offline
post #5 of 12 Old 11-03-2011, 08:44 AM
Quail
Exactly, I store my trailers and campers this way and havnt had to buy a tire for any of them in over 15 years. They all look brand new and some of them sit for 2 or 3 years at a time. I just use concrete blocks.
You can get a uv blocker at camper dealers that really works. I know some guys rub thier tires down with vasoline for storage.
There is some talk about filling tires with nitrogen for storage helps as well.
I have started going out and rotating the tires periodicly, For some reason if the tire is allowed to stay in one position for a long time the bottom of the tire gets heavier and if you spin the tire it will return to that position.
Yes crank it and run it once a week, Run the heater! and if you have AC run that too.
Quail is offline
post #6 of 12 Old 11-03-2011, 10:35 PM
dodger889
Use gas stabilizer in the gas tank. Fill the yank all the way to full and if you are running it refill once in a while.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #7 of 12 Old 11-04-2011, 07:26 AM
UZI4U
Parking it for the winter? It's going to waste by doing that. I can't wait for the snow to start flying.
MCLMM
UZI4U is offline
post #8 of 12 Old 11-04-2011, 07:31 AM
LilyBayXJ
If it's being parked on the dirt, make sure you park it on a tarp. Not just under the tires, under the whole Jeep. Believe it or not, it makes a huge difference in preventing rust.
2006 LJ - 4.0L, NSG370, 31's
2001 XJ - 4.0L, AW4, 3.5" lift, 31's
1997 TJ - 2.5L, AX5, 2.5" lift, 32's - Sold
1983 CJ-5 - Stock - Sold
LilyBayXJ is offline
post #9 of 12 Old 11-04-2011, 07:33 AM
oldtime_ironman
^^^^ X2 on the gas stabilizer. One popular brand up north here, is "Sta-Bil". I see more people that don't use it, and then they go thru all kinds of crap trying to start up again in the spring. So definitely use it. Just pour a bottle in the tank when you park it. Top it up with fresh gas ASAP after you start driving it again.
post #10 of 12 Old 11-04-2011, 07:58 AM
1998zj
Just drive it and you won't have to mess with all this.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #11 of 12 Old 11-04-2011, 08:03 AM
oldtime_ironman
Yeah, I DD mine year round... can't wait for the snow, that's when I pop into 4X4 and start having FUN!!!
post #12 of 12 Old 11-05-2011, 07:57 AM Thread Starter
CJ51973
CJ51973's Avatar
Full time locker + short wheel base+ ice and low level snow = unexpected donuts. I will be fine in my unlocked Cherokee. Plus it saves me insurance (5 vehicles). I like the tarp idea. If we get a deep snow I will be all over it though!
CJ51973 is offline
top down in winter trav_k1234 Wrangler General Discussion 36 01-22-2014 10:34 AM
parking break problem, i need my parking brake ClassicRiderhp TJ Wrangler Technical Forum 2 04-21-2010 09:21 AM
TJ Winter Winter Beater Special Edition? TJSAILOR3385 TJ Wrangler Technical Forum 14 12-20-2008 05:55 PM
Winter 4x4 lesevensixfour YJ Wrangler Technical Forum 15 11-25-2007 10:51 PM
Tires: daily driving winter roads... yes or no to winter tires? TwinsJeep JK Wrangler Technical Forum 8 11-29-2006 05:56 PM
