Parking/taillights stuck "on". - JeepForum.com
post #1 of 11 Old 01-18-2005, 07:49 PM Thread Starter
lordmatt
lordmatt's Avatar
After the last wheeling trip I went on, my parking and tail lights stay on constantly. I can flip the headlight switch on/off and the go on/off, but the parking and tail lights stay on.
I would assume something is grounding out somewhere. I would also assume it's a wire somewhere outside of the cab. Any ideas? I'm not sure where to start exactly...
'91 YJ - Flat Black
35x12.50x15 BFG Mud-Terrain TA's on 15x8 Black Rockcrawlers
SOA, SYE
Cut fenders
Recessed tails
Herc's interior
Fabbed front bumper
misc fun stuff
lordmatt is offline
post #2 of 11 Old 01-18-2005, 08:41 PM Thread Starter
lordmatt
lordmatt's Avatar
Pretty sure this means something, but not sure what:
When I pull the Dome fuse, both the tail/parking lights go out. Also, when I turn the dial to brighten or dim the dash lights, it also brightens/dims the parking/tails.
'91 YJ - Flat Black
SOA, SYE
Cut fenders
Recessed tails
Herc's interior
Fabbed front bumper
misc fun stuff
lordmatt is offline
post #3 of 11 Old 01-18-2005, 09:18 PM
oct7brian
oct7brian's Avatar
What about the sensor/switch down by the pedal. I had the same sort of problem on my S10 and it ended up being a stuck pedal switch.
1998 Grand Cherokee 5.9 Limited Edition, Upcountry Suspension for Now, Infinity Sound, NP 242 Swap
2002 Jeep Liberty Sport 4x4 3.7L Auto
1998 TJ 4.0 Auto Sahara Package 4" Suspension Lift 33 BFG Hard & Soft Top
oct7brian is offline
post #4 of 11 Old 01-18-2005, 09:20 PM Thread Starter
lordmatt
lordmatt's Avatar
I thought that's what it was at first, too, but this happens with the parking lights as well as the tail lights. (I had to fix the stuck brake light deal already )
'91 YJ - Flat Black
SOA, SYE
Cut fenders
Recessed tails
Herc's interior
Fabbed front bumper
misc fun stuff
lordmatt is offline
post #5 of 11 Old 01-18-2005, 09:32 PM
Lins
sounds like there's some kind of short between the interior and exterior lights. exterior lights are probably grounding through the interior switch, which is why you can dim them. faulty ground for exterior lights, or crossed interior/exterior wires?
Lins is offline
post #6 of 11 Old 01-18-2005, 11:14 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
close, but looking at the schematic for the 91, my guess is the panel dimmer switch itself has gone bad, or there's a short in its harness. it's a power feed issue i think, not a ground issue. the dimmer is a double pole switch and one side is connected via the dome/courtesy lights to the fuse you pulled which is providing power at all times (lights come on without the key in of course). the other half of the switch is connected to the headlight switch at the same splice as the tail/parking lights. my guess is either those internal terminals have shorted together, or the wires have shorted and are cross feeding current which is powering your tail lights. pull the fuse and see if they still come on with the headlights. if so, then you can just leave the fuse out until you have a chance to change out the switch or hunt down your short.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #7 of 11 Old 01-19-2005, 08:18 AM Thread Starter
lordmatt
lordmatt's Avatar
I just pulled the fuse for now. Not like I ever look at the dash at night anyway... I'll just tack it up as another thing that needs fixed.
'91 YJ - Flat Black
SOA, SYE
Cut fenders
Recessed tails
Herc's interior
Fabbed front bumper
misc fun stuff
lordmatt is offline
post #8 of 11 Old 01-19-2005, 08:43 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
The common point in the whole thing is the headlight switch unit. It controls all the lights you are having problems with. I'd replace it.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #9 of 11 Old 01-19-2005, 10:26 AM
sentinal02
sentinal02's Avatar
if the headlight switch was providing power all the time, then pulling the dome fuse wouldn't shut them off. take a look at the schematic and you'll see what i mean.
post #10 of 11 Old 06-28-2013, 02:29 AM
Brownguy84
I'm having the same issue, any solutions?????
Brownguy84 is offline
post #11 of 11 Old 06-28-2013, 07:33 AM
UZI4U
Your best bet is to isolate where the problem is. It's not at the fuse panel. Try disconnecting at each of the switches and checking for shorts/ohming the switches. You'll figure it out.
MCLMM
UZI4U is offline
90 YJ Stuck in Gear "" HELP "" harleynut05 YJ Wrangler Technical Forum 17 09-16-2009 05:41 PM
Parking Brake conversion: TJ "pull" style into YJ aleksandrc YJ Wrangler Technical Forum 8 04-18-2007 09:32 AM
'97 SE Fuel Gauge Stuck At "F" retroflow TJ Wrangler Technical Forum 8 04-21-2006 04:31 PM
1995 "Parking" lights Cherokee Sport SWMSGoodman YJ Wrangler Technical Forum 1 02-12-2006 04:11 PM
got my 3" and 33"s on, and promptly got stuck! (pics) 2k2wranglerx TJ Wrangler Technical Forum 8 02-12-2003 10:09 PM
