parking brake wont work - JeepForum.com
post #1 of 9 Old 07-27-2013, 11:31 AM Thread Starter
Mevans8894
My parking brake won't work.. Ive replaced the cables rebuilt both sides. it seems the PArking brake strut/equalizer is too short because it is very loose between the shoes.. I have 9" drum brakes on the rear
Mevans8894 is offline
post #2 of 9 Old 07-27-2013, 11:42 AM
bigbossd1030
Are you adjusting it right? The Haynes manual has step by step instructions on how to adjust them. I don't remember exactly, but ill check my manual when I make it out to the jeep.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #3 of 9 Old 07-27-2013, 12:05 PM Thread Starter
Mevans8894
I have the Haynes manual and adjusted it as well as I can. This is my first time with drum brakes, so I may be doing something wrong. Ive tightened the adjuster, under the driver seat, almost as tight as it can get, and it still wont pull the lever arm far enough to tighten up the equalizer bar. Also when i took the brakes apart, the equalizer bar "arch" went up, but when i put it back together, the arch had to face down or it wouldn't go in.. Thanks for the help
post #4 of 9 Old 07-28-2013, 07:13 AM
Mark05059
take a picture of your rear brakes.. (drum off)
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 9 Old 08-03-2013, 12:10 PM Thread Starter
Mevans8894
sorry it took so long... i have to drive it during the week. I use a 4X4 piece of wood to block the jeep if i have to park on a hill
post #6 of 9 Old 08-03-2013, 01:41 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Here's a solution. Take it to the dealership and if the parking brake recall hasn't been done, they have to make sure everything works by law. For free.
Luck Favours The Prepared
Anticanman is offline
post #7 of 9 Old 08-03-2013, 02:52 PM Thread Starter
Mevans8894
I checked with the dealership and it has not been completed.. You say they have to make sure the whole system works by law and will fix it for free??
post #8 of 9 Old 08-03-2013, 02:58 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I'm no lawyer but they have to make the adjustments to test it to complete the recall mandate.
Its worth a shot instead of going backwards and fixing it again.
post #9 of 9 Old 08-03-2013, 03:10 PM Thread Starter
Mevans8894
Thanks for the help... Im putting it in the shop Wed morning..
