Parking brake tension assembly- cheap repair - JeepForum.com
post #1 of 6 Old 12-18-2007, 02:36 PM Thread Starter
DeclarationDay
Hello, new guy here. I did a cheap fix on my parking brake tensioner assembly today, and thought I'd share the info.
I bought my YJ a few months ago, and one of its quirks was that the parking brake cable wasn't tight enough. I crawled under the frame to wrench down the nut, and it was hopelessly rusted shut; any attempt to turn it would have snapped the bolt.
So I went to the Stealership yesterday to buy a new tensioner assembly, and they wanted $32 for it. I though this was a bit high, so I decided to tackle the problem myself.
I would have had more detailed pictures of the repair, but doing a write-up didn't occur to me until after I was done
First, I cut off the old bolt and nut, along with the hook that held the head of the bolt to the primary parking brake cable detent:
I opted to replace the old tension bolt with a larger diameter one, so I used a dremel tool and grinder bit (I'm sure you could just drill it too) to enlarge the hole on the cable detent. I purchased an 8" long bolt and self-locking nut from the hardware store, and assembled the parts. Note, the bolt has to be much longer than the original one because it also replaces the hook assembly.
Works perfectly, total cost: $1!
Freedom is worth any price.
DeclarationDay is offline
post #2 of 6 Old 12-18-2007, 03:59 PM
jonnyri
jonnyri's Avatar
I did the exact same thing. with a couple modifications...
I used 3/8" threaded rod, 2 locking nuts at the adjustment - one on each side to tighten the threaded rod to the bracket, and another two regular bolts tightened against each other at the equalizer.
Dirty, rusty, banged up YJ.
OSJ / NEA Delegate
jonnyri is offline
post #3 of 6 Old 12-18-2007, 06:31 PM
timatoe
timatoe's Avatar
No Clicky
timatoe is offline
post #4 of 6 Old 12-18-2007, 06:46 PM
Btwngreengray
I had the same problem with the tensioner being rusted stuck and stuff, but it went fairly easy for me. I just used buttloads of PB Blaster and heat till the nut came off. I polished the whole assembly on the bench grinder and now it looks good as new. The dealership here wanted over $100 for a new one. I also changed the cables at the same time and did my rear brakes. All in a day's work.
"If ye love wealth better than liberty, the tranquility of servitude than the animated contest of freedom, go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that you were ever our countrymen! Samuel Adams.
Christian Jeep Club Member #104
Btwngreengray is offline
post #5 of 6 Old 12-18-2007, 07:07 PM Thread Starter
DeclarationDay
oops, double post.
post #6 of 6 Old 12-18-2007, 07:08 PM Thread Starter
DeclarationDay
Yeah I did the rear brakes too, and though the cables have some rust on them they still work fine. Replacing them is probably a good idea, but I don't want to spend the $$ replacing non-critical parts that still work.
Strange Brake Problems & Parking Brake issue Tmsnake1 TJ Wrangler Technical Forum 16 02-24-2012 07:19 AM
How do you remove the parking brake pedal assembly? veritas4156 YJ Wrangler Technical Forum 8 03-15-2010 07:42 PM
parking brake assembly recall YJ_95 YJ Wrangler Technical Forum 19 05-07-2008 11:34 AM
Parking brake pedal assembly veritas4156 YJ Wrangler Technical Forum 12 05-06-2008 07:58 PM
Has anybody replaced the foot parking brake with hand brake jake100 YJ Wrangler Technical Forum 0 06-11-2002 10:19 PM
