Parking Brake LED dash light not working - Page 4 - JeepForum.com
post #46 of 83 Old 05-17-2013, 07:56 PM
Old4X
1990 CJ7
How about ignition feed to radio?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #47 of 83 Old 05-17-2013, 08:12 PM Thread Starter
CBinDC
I was hoping to find a connection In the mess of wires behind the speedo and tach. I'll look through them tomorrow. I have them all labeled. Not that they're all correct!
My biggest concern is that when I turned on engine, the parking brake was set but the LED didn't come on.
CBinDC is offline
post #48 of 83 Old 05-18-2013, 04:59 AM Thread Starter
CBinDC
Ok. So here are the lines I have available that are not being used: up shift indicator (at least that's what I labeled it - I don't remember it ever having an up shift light in the dash though), service warning Indicator (i didn't hook this up to my dash because I did the nutter bypass and im not sure how useful this is now - i know Im a noob - i will be starting a thread inquiring about this in the near future), and ignition 12v feed (although it is being used to power my speedo, I can still tap into it).
CBinDC is offline
post #49 of 83 Old 05-18-2013, 05:23 AM
Que89YJ
just hook it up to the switched ignition feed going in. use a 20 guage wire and run it to the socket. use a couple dabs of rtv to hold it in place.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #50 of 83 Old 05-18-2013, 01:07 PM Thread Starter
CBinDC
I did as Que suggested, tapped into the 12v feed, and now I have a working light. Thanks guys! Now, onto my 4wd indicator light. : )
CBinDC is offline
post #51 of 83 Old 05-18-2013, 03:21 PM Thread Starter
CBinDC
Now the 4wd indicator light, I looked in the manual and it indicated that the black/ yellow wire is the ground for the 4wd indicator light. So I hooked that wire up to the ground of the LED and then I tapped into the 12v feed again for the power because it worked for the brake light.
I turned on the engine, put it in the 4wd, and the light isn't working. What next? Was it not a good idea that I re-tapped back into the 12v ignition feed?
CBinDC is offline
post #52 of 83 Old 05-18-2013, 03:34 PM
Michaelgoesrawr
Did your 4x4 light ever work? Do you still have all of the vacuum stuff under the hood. There is a better chance your switch is bad instead of your light and wiring.
Edit: your Jeep also has to be running for the light to work.
Michaelgoesrawr is offline
post #53 of 83 Old 05-18-2013, 03:42 PM Thread Starter
CBinDC
It did work at one time but it was loooong before I did the nutter bypass and yanked a bunch of vacuum hoses. Would this be the issue?
CBinDC is offline
post #54 of 83 Old 05-18-2013, 04:03 PM
Michaelgoesrawr
It very well could be. There needs to be vacuum from the cad on your axle to the switch next to the battery. It's a blue thing. Unplug the wire and ground it with the ignition turned on. If the light comes on(assuming the rest of your wiring is correct) its a vacuum problem from the cad.
post #55 of 83 Old 05-18-2013, 04:18 PM Thread Starter
CBinDC
Will the 4wd still work if the vacuum from the CAD is not working properly?
CBinDC is offline
post #56 of 83 Old 05-18-2013, 04:35 PM Thread Starter
CBinDC
I'm just trying to determine if I want to bother with it.
CBinDC is offline
post #57 of 83 Old 05-18-2013, 04:41 PM Thread Starter
CBinDC
This is the only "blue thing" I see near the battery:
CBinDC is offline
post #58 of 83 Old 05-18-2013, 05:58 PM
Michaelgoesrawr
Sorry. It's on the firewall next to the battery. Yeah the 4wd should still work id imagine. You need a vacuum source from the motor but I'm not sure how the rest works.
post #59 of 83 Old 05-18-2013, 06:57 PM Thread Starter
CBinDC
Sorry, I don't see anything on the firewall near the battery. I have an '89 YJ. Maybe we have different years/ models. ??
CBinDC is offline
post #60 of 83 Old 05-18-2013, 07:57 PM
Michaelgoesrawr
Mines am '88. They didn't change the system until the '90's I thought. Do you have electrical connectors on the cad on the axle? There should be an orange/black wire in the loom that goes by the battery somewhere.
This is what the switch looks like.
This is the connector in the engine bay
Edit: You can pm me your number and I'll help how I can.
