Parking Brake LED dash light not working - Page 3 - JeepForum.com
post #31 of 83 Old 05-16-2013, 09:05 PM
Old4X
1990 CJ7
Originally Posted by CBinDC View Post
Where can I get a buzzer?
Rat Shack
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #32 of 83 Old 05-17-2013, 06:47 AM Thread Starter
CBinDC
Originally Posted by Old4X
Rat Shack
I don't want to get too off topic here but how many dB and amps would be sufficient. I am not an electronics guy. I'm sure you've already figured that out. Haha
I saw on the shack a couple buzzers that might work:
http://m.radioshack.com/radioshack/p...egoryId=&path=
I have no idea what all the numbers mean. What makes it loud, whether it be amps, volts, Hz, or dBs.
CBinDC is offline
post #33 of 83 Old 05-17-2013, 06:53 AM Thread Starter
CBinDC
So I went out this fine morning to take a look and found that the wire I had going to the power of the LED looks the same as the ground wire going to the parking brake pedal. They are both grey with a black stripe.
This is why I used that wire as the power:
Am I wrong here? Is it just coincidence that the ground wire and the power wire are the same colors?
CBinDC is offline
post #34 of 83 Old 05-17-2013, 07:31 AM Thread Starter
CBinDC
Here are some other diagrams:
This is SH 7
At the top of the page it says (SEE SH 43)
So here it is SH 43
It is clearly a Grey wire with black stripe. So is this the ground or the power? If this is the power, where is the ground.
I'm so confused.
CBinDC is offline
post #35 of 83 Old 05-17-2013, 07:49 AM
Old4X
1990 CJ7
It is the ground, see the indicator for ground where the switch is?
Old4X is offline
post #36 of 83 Old 05-17-2013, 07:51 AM
Old4X
1990 CJ7
Looks like you have hooked a ground to both sides of your bulb. Won't work that way.
Also, polarity will mess you up on leds if not right
Old4X is offline
post #37 of 83 Old 05-17-2013, 08:08 AM Thread Starter
CBinDC
If you look at SH 7, you see the parking brake switch. It's an open switch, I'm guessing it's activated when you push down on the p brake. It shows that it's grounded on one side. And I'm guessing the grey/ black wire coming off of it is just a continuation of that ground? So where is the power? I can't seem to figure out what color that wire is.
However, there is an orange/ black wire that has been used to illuminate the LEDs for the tach and Speedo. I know there are a couple of these left that have not been used. Would one of these work? Just asking so I don't fry something. The worst thing is to damage something, especially as seemingly small as a LED, have to reorder and then wait another few days to re-do. Thanks for your help Old4X.
CBinDC is offline
post #38 of 83 Old 05-17-2013, 08:19 AM Thread Starter
CBinDC
Yeah definitely looks that way.
CBinDC is offline
post #39 of 83 Old 05-17-2013, 08:24 AM
Michaelgoesrawr
Michaelgoesrawr's Avatar
It looks to me like they used the same color wire for both the ground and the hot. On 43(I apologize if that's not right on my phone so can't see posts) I really want to say that's the hot. It does say input and it doesn't show ground like the other pictures did.
There is a wire that powers the ribbon. Maybe if you trace the ribbon where the bulb sits in place down to where it connects to a wire? I'd figure they would all be connected to the same hot because they are a low amp draw and everything is operated by ground.
Michaelgoesrawr is offline
post #40 of 83 Old 05-17-2013, 08:30 AM Thread Starter
CBinDC
I think it's the orange/black wire. It's the same wire that powers the LEDs to my Tach and Speedo. I think I'm going to connect that to the power and take the grey/ black wire and put that on the ground.
When I connected the grey black wire to the hot side of the LED, it just showed my inexperience with reading these elec. diagrams. Now when I see the diagram, I can clearly see why it is the ground.
CBinDC is offline
post #41 of 83 Old 05-17-2013, 09:05 AM Thread Starter
CBinDC
Possibly a dumb question but not sure, so I'll ask. The Orange power wire that is used to illuminate the speedo and tach is an 18g wire. The power wire for the parking brake dash LED is 20g. Would it be ok to go from a higher gauge power source (12v, 18g) to a smaller gauge wire of the LED (12v, 20g)?
CBinDC is offline
post #42 of 83 Old 05-17-2013, 09:33 AM
Old4X
1990 CJ7
If you are asking to substitute a lighter wire for a heavier one, tha answer is usually no, unless you know every component that wire powers, and you are using fewer amps in your new configuration.
LEDs draw less amps than tungsten filiment bulbs.
But your question sounds like you are going to tap the lighting circuit, that is not the proper power source. It should be a hot off the ignition switcs. The lighting circuit is dead unless thge lights are turned on.
I may have read your intention wrong, though
Old4X is offline
post #43 of 83 Old 05-17-2013, 10:21 AM
Michaelgoesrawr
This. If I'm not mistaken he could probably tap into the turn signal circuit for the indicator. They have power as the brake light indicator would.
post #44 of 83 Old 05-17-2013, 11:17 AM Thread Starter
CBinDC
Haha this is exactly what crossed my mind. When I realized that tapping into the lighting circuit would basically provide constant power to the LED, I looked for another option. That's when I saw I could tap into the turn signal line.
I tried jumping my battery. Unfortunately, it is done.
CBinDC is offline
post #45 of 83 Old 05-17-2013, 07:33 PM Thread Starter
CBinDC
Well I FINALLY got a new battery after going to 6 auto stores. I needed a battery with a BCI of 56, all I could find we're 58s. Anyways, finally I got home, hooked it up, tapped into the left turn signal circuit, and when I turned on the engine, nothing. However, when I turned on the left turn signal they were beautifully synchronized, blinking. Obviously, this is not the wire I want to use. Sheesh!
CBinDC is offline
