Parking Brake LED dash light not working - Page 2 - JeepForum.com
post #16 of 83 Old 05-16-2013, 04:06 PM
Old4X
1990 CJ7
Originally Posted by CBinDC View Post
Well, I know that without a good ground the light won't work. Am I right?
Correct, but it doesn't ground at the dash cluster, it grounds at the brake pedal.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #17 of 83 Old 05-16-2013, 04:43 PM Thread Starter
CBinDC
Are you saying I need to run the ground to the pedal?
CBinDC is offline
post #18 of 83 Old 05-16-2013, 05:09 PM
Michaelgoesrawr
There is already a wire that runs from the dash to the pedal. He's just saying the dash is grounded at the pedal and the body where they meet.
Michaelgoesrawr is offline
post #19 of 83 Old 05-16-2013, 05:11 PM
Old4X
1990 CJ7
By pedal you are talking emergency brake pedal.
Yes, the ground side of the dash light goes to the wire on top of the emergency brake light switch. It also goes to the purportioning valve to indicate a failed brake hyd circuit. When either switch closes, it completes circuit to ground.
Did you test the bulb before install? You should be able to use a jumper (to ground) to light it to test the socket and power to bulb.
If nogo with the jumper, break out the test light or multi-meter and see why no power.
Old4X is offline
post #20 of 83 Old 05-16-2013, 05:45 PM Thread Starter
CBinDC
Is this what you're talking about?
CBinDC is offline
post #21 of 83 Old 05-16-2013, 06:16 PM
Michaelgoesrawr
Yep
post #22 of 83 Old 05-16-2013, 06:51 PM Thread Starter
CBinDC
Originally Posted by Michaelgoesrawr
Yep
So that wire coming off there is the ground wire?
CBinDC is offline
post #23 of 83 Old 05-16-2013, 07:02 PM
Michaelgoesrawr
Yeah buddy.
post #24 of 83 Old 05-16-2013, 07:18 PM
GunslingerSql1
Hey ummm on the same subject. Mine brake light won't go off. Don't want to hi-jack your thread but figured since you guys were kinda already on the subject I'd ask.
GunslingerSql1 is offline
post #25 of 83 Old 05-16-2013, 07:52 PM Thread Starter
CBinDC
Yeah buddy.
Alright thanks. I'll take a closer look tomorrow. When I got home later today, I couldn't test the voltage cause my battery was dead. I accidentally left one of the doors open, after doing some wiring work last night, and the interior lights were inadvertently left on. I can't remember if there was ever a buzzer/ alarm that would go off when doors were left open. Does anyone know? I have a '89 YJ. If not, can I rig one up?
Tomorrow I have the morning off, so I'll recharge my battery and take a closer look at the wiring. I think I got my wires crossed somewhere. No pun intended.
Thanks for all your help!
CBinDC is offline
post #26 of 83 Old 05-16-2013, 07:58 PM Thread Starter
CBinDC
Funny! Earlier today when I did a google search on my problem I found this:
http://www.wranglerforum.com/f8/brak...on-144026.html
Not sure this will help you but at least it's a start. My google search was "YJ Jeep brake dash light not working". Hope you figure it out. Good luck!
CBinDC is offline
post #27 of 83 Old 05-16-2013, 08:09 PM
Old4X
1990 CJ7
I have found the door activated lights rather usless and prone to do what happened to you. I disconnect my switches as I often have the doors open or off completely.
Old4X is offline
post #28 of 83 Old 05-16-2013, 08:17 PM
Michaelgoesrawr
Yeah you can rig a buzzer. It needs power and you complete the ground with the door switches.
post #29 of 83 Old 05-16-2013, 08:46 PM Thread Starter
CBinDC
Yeah, I get what your saying. I'm thinking about doing the same but then again, I do like the idea of a light down there. Maybe it would be a good idea to rig some better lighting down and tie in a buzzer.
CBinDC is offline
post #30 of 83 Old 05-16-2013, 08:47 PM Thread Starter
CBinDC
Where can I get a buzzer?
CBinDC is offline
