Parking brake does not work - JeepForum.com
post #1 of 19 Old 09-08-2011, 01:47 PM Thread Starter
monkey710
Ok all, pardon my nubliness, but I just don't know where to start on this. I bought a 89 YJ and the parking brake does not work. It had been lifted and now has 33" tires on it. The previous owner never used it so he never noticed this issue. I don't normally use it either, but I am shipping it overseas for my move and they require it to work before loading it on the boat. It feels loose when pushing in like the cable is too loose, so I guess I will start there...any other ideas?
monkey710 is offline
post #2 of 19 Old 09-08-2011, 01:58 PM
Andywear
Crawl underneath and look at cables. tighten them if possible.
Also, go thur the stickys and find out if your Jeep has had the rework done on the brake lever.
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #3 of 19 Old 09-08-2011, 02:25 PM Thread Starter
monkey710
I tried adjusting the tension on the cable, but when the brake is engaged there is no more cable to pull out...it seems to be pulling a total of about 5 inches on rear cable. Something to do inside the drum? Something related to the larger wheels?
post #4 of 19 Old 09-08-2011, 02:25 PM Thread Starter
monkey710
The mechanism seems to operate fine, just not stopping vehicular motion.
post #5 of 19 Old 09-08-2011, 02:27 PM
Andywear
Alright your now part of the Parking break that doesn't work club.
Welcome and enjoy your time here.
Andywear is offline
post #6 of 19 Old 09-08-2011, 02:28 PM Thread Starter
monkey710
Yay...I feel so special...I guess to the shop it goes before I move...
post #7 of 19 Old 09-09-2011, 07:39 AM
nembudonna
The cable is to long. It's a factory thing. You can take it apart and put a spacer behind the cable and the ajuster.
nembudonna is offline
post #8 of 19 Old 09-09-2011, 09:36 AM
LordEnki
2006 WK
So, how does this spacer go on? At the pedal end? Any pics available?
LordEnki is offline
post #9 of 19 Old 09-09-2011, 09:55 AM
tdewit
First adjust the brakeshoes properly before adjusting the e/brake. Does wonders.
tdewit is offline
post #10 of 19 Old 09-09-2011, 11:43 AM
imstillatwork
Ever YJ I test drove (EVERY ONE OF THEM) had poorly adjusted rear brakes. This affects the function of the parking brake.
Jack up the rear wheel, use a flat screwdriver (or drum brake adjuster tool if you have, better angle, easier) and adjust the shoes. This is done from the oval shaped port on the dust cover behind the drums. Adjust them until you can JUST feel the wheel drag, then back it off a click. (that's how I do mine anyways...)
The stopping ability is so much better with proper adjustment too.
imstillatwork is offline
post #11 of 19 Old 09-09-2011, 06:54 PM
mazyj
This should fix you ebrake and get you stopping quite a bit better- at least for a couple weeks
91 wrangler 4.0L, 4 in Suspension lift, 1 inch Shackle Lift, 1 inch Body Lift, 35" BFG Mud Terrains, Warn Rockcrawler Front Bumper, Hand Throttle, HiLift, 12 pack of Natty Boh.
mazyj is offline
post #12 of 19 Old 09-09-2011, 07:04 PM
nzpete
I lived in Germany for 10 years while stationed in the military and trust me, you'll want to have everything on your Jeep fixed now, before your go. If you think repairs are expensive here, just wait till you get "there".
Instead of trying to figure out your parking brake issue, replace the rear brakes and drums and have them adjusted properly.
If you have anything "iffy", get it done now or you'll regret it later.
To me, RC is kind of the Harbor Freight of springs. Sometimes you get a good deal and sometimes you don't.
nzpete is offline
post #13 of 19 Old 09-10-2011, 06:26 PM Thread Starter
monkey710
Yeah, especially since I am being transferred to Bahrain!!
But I don't think it is the cable, it pulled the cable out from the brake side of the equalizer and there is no more play. I think it is in the drum/shoe itself. That is the next path I am going down.
post #14 of 19 Old 09-11-2011, 06:46 AM
nzpete
I spent two tours in the "middle east", too, and it is even worse! Bahrain isn't quite as bad as some places you could go to, but you would do well to get things done now. You might even think about buying and shipping a few spare parts just in case. Good luck!
nzpete is offline
post #15 of 19 Old 09-11-2011, 08:05 AM
Karma
HI,
The rear brakes on an '89 YJ are self-adjusting. They adjust every time you are moving in reverse and apply the brakes. However, it would be a good idea to manually adjust them just to make sure of where your starting point is.
Sparky
Karma is offline
