Parking Brake Cable too long? Need help with adjustment - JeepForum.com
post #1 of 5 Old 08-23-2011, 08:18 AM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Hello everyone
I just bought replacement cables for the parking brake, bought three cables, one from the pedal to the equalizer under the jeep, then one for the right/one for the left...
I am not doing the installation since I have no time now but my mechanic tells me one of the cables is about 2" longer and the other one is 1" longer... does this sound normal? I ordered the cables for my model/year... Is there any adjustment that can be made to fix this? I wish I could do it myself but I'm swamped with work
All help is appreciated, seems to me this is more of an adjusting issue.
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #2 of 5 Old 08-23-2011, 12:56 PM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Bump
Fernando is offline
post #3 of 5 Old 08-24-2011, 05:16 AM
CJ51973
CJ51973's Avatar
My 88 had a D35 out of a 94 . The cables were too long for the stock adjustor. I ended yp using a 3/4" pipe nipple to sleeve out to the adjustment so I could tighten things up. Right & left cables are two different lengths. All I know about it.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #4 of 5 Old 08-24-2011, 05:39 AM
EABiker
You can un-tension the main cable, wrap it around a half inch bolt, sandwiched between 2 washers to shorten it overall by aound by around 1.5 inches if my math is right!
EABiker is offline
post #5 of 5 Old 08-24-2011, 08:58 AM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Thank you guys for your input, in the end, it all checked out, apparently all that was necessary was proper adjustment of the brake shoes and the drum mechanism... everything fit right then
I appreciate your help!
Fernando is offline
parking brake adjustment Help PLEASE! CharlieHarper JK Wrangler Technical Forum 4 03-10-2011 05:26 AM
Parking Brake Adjustment fishsniper YJ Wrangler Technical Forum 4 12-03-2010 05:27 AM
Parking brake adjustment help please RubiconChris TJ Wrangler Technical Forum 20 04-12-2010 08:47 PM
Parking Brake Adjustment his15153 TJ Wrangler Technical Forum 9 08-30-2006 12:40 PM
Adjustment on Parking Brake 9double8 YJ Wrangler Technical Forum 2 01-07-2006 02:08 PM
