Parking brake cable removal - JeepForum.com
post #1 of 7 Old 10-22-2012, 04:32 PM Thread Starter
kjg26
kjg26's Avatar
1993 YJ
I've gotten the front half free from the rear half at the splitter. Not i'm just trying to get the rear half free from the frame. There are "keyholes" that the cable passes through. the cable has "flares" that pop out and catch the keyhole so they don't pull free. I, for the life of me, can't find a good way to remove these. I'm replacing my drum brakes with disc brakes from a 96 grand cherokee. I have played with this release on the GC brakes and was able to use a small hose clamp to compress the flares. But can't manage that with the brakes on the jeep. Any help? Suggestions? Tools?
Thanks
Keith
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #2 of 7 Old 10-22-2012, 04:37 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
A pair of pliers should release the catches on them.
Luck Favours The Prepared
Anticanman is offline
post #3 of 7 Old 10-22-2012, 04:41 PM Thread Starter
kjg26
kjg26's Avatar
there is 4 catches. on a clock face they would be at 12,3,6,9. I can't figure it out. I'm getting flustered. Maybe i'll take a breather from it.
kjg26 is offline
post #4 of 7 Old 10-22-2012, 04:55 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Use the rounded inner jaws while rotating the cable so that the 12 clock is at the 2 o'clock and attack from the bottom.
post #5 of 7 Old 10-22-2012, 05:15 PM
jbolty
jbolty's Avatar
try a 1/2 drive deep socket to compress the tabs. I think 1/2 is the size that works
Many, many, many years ago I made a tool for that out of an old socket with a notch cut for the cable to pass thru.
jbolty is offline
post #6 of 7 Old 10-23-2012, 05:22 AM Thread Starter
kjg26
kjg26's Avatar
Half inch box end wrench jammed all the way up did it. Thank Yall so much!
kjg26 is offline
post #7 of 7 Old 10-23-2012, 09:29 AM
crackedcornish
I use a small worm gear hose clamp tightened enough to compress those little spring fingers, then just punch the housing through the hole with the screwdriver i used to tighten the clamp
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
