parking brake cable adjuster - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > parking brake cable adjuster
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 06-04-2011, 05:39 PM   #1
acat
anyone got a link to a pic or schematic of how the parking brake cables go together on a yj. I need to know how the metal bracket pieces go together that tie the single main cable to the rear individual cables. Located by the drivers side frame rail in front of rear tire.
thanks
acat is offline   Reply With Quote Quick reply to this message
Unread 06-04-2011, 10:50 PM   #2
clarkjdg
Im not for sure what you want but I took a picture of where the two cables tie togeather with one. Sorry the picture isnt to good but its real dark out there.
LIVE EVERY DAY LIKE IS WAS YOUR LAST...
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
88 YJ, Smittybilt SRC Front, Side, and Rear Armor, Family Roll Bars, TJ Flares, and Half Doors
4"Leaf, 2"Body, and 1"Leaf Lift, 4.10 Geared Dana 30 Posi with Cable Engage, Ford 8.8 Posi, With 33s BFGs MT KM2
Everything "Black" Inner, Under, and outer "Black" on the Body is "Bed Linered" and I will be Thru the day that I Die!
clarkjdg is offline   Reply With Quote Quick reply to this message
Unread 06-05-2011, 10:00 PM   #3
acat
thanks for the pic. I think I figured out whats going on. Ive got the equalizer and cable adjuster but my main cable from the pedal wont hook into it. Instead of having a solid anchor (or whatever you'd call it) on the end it has a threaded rod. No way to get it to hook into the brake adjustment linkage. I ordered it years ago and never ended up finishing hooking it all up. It looks like its the cable used on 87-89 yjs. What stinks is that I'm sure I can't return it and I remember it being pretty expensive. Im thinking of bolting this threaded rod right into the equalizer and not using the other part of the adjuster mechanism. Any reason why this shouldn't work for me. Anyone got a pic of a pre 90 YJ ebrake setup at the adjuster. Maybe they used a different style adjuster that I could pick up.
