Park lights blow fuse, one turn signal out - JeepForum.com
post #1 of 3 Old 05-21-2013, 09:32 AM Thread Starter
maicorider
2005 YJ Wrangler
2005 Wrangler, 6cyl 6speed.
Just bought this jeep, checked over all but forgot to check parking lights.
Upon return to home found that parking lights won't light and 20 amp fuse was blown. Replace fuse and it blew again. Check all bulbs and wiring that can be found easily. Replace fuse and lights worked for a few minutes, turn on auxilary driving lights and fuse blows again. Auxilary lights still work.
Go back and check all wiring again can't find any short to ground with wires.
Now the drivers side turn signal does not work. It worked fine and all of a sudden it stopped. Rear drivers side works, light blinks fast due to no load on front light. Voltage at front light connector appears to ramp up to about 6 volts so it is being held back.
Dash lights don't work and interior lights over roll bar only turn on when you activate switch on column. Interior lights don't light when door is opened. Light under dash won't light but this may be the bulb.
Is the light switch control circuit contained in the steering column or is it under the dash?
I believe this circuit board has issues, saw another post about this but don't know if I should pull the unit out of the column or if the circuit board is located somewhere else.
thanks for any help.
Brad
maicorider is offline
post #2 of 3 Old 05-21-2013, 09:46 AM
Cooter92YJ
You probably need to head over to the TJ section. The guys here are more used to working on the older YJs. Sound like possilbly several issues.
Originally Posted by Luuca
Welcome to the wonderful world of YJs... you'll soon learn how to listen, feel, and smell your way into vehicle diagnostics!
Cooter92YJ is offline
post #3 of 3 Old 05-24-2013, 09:20 AM Thread Starter
maicorider
2005 YJ Wrangler
Problem solved
Main problem was the turn signal light control switch. Bought new unit at Napa Auto for $78.00. Very easy to replace, 2 screws to remove plastic cover over column and 2 that held unit in place. 2 electrical connectors and that was it.
