Painting soon! Couple questions.! - JeepForum.com
post #1 of 15 Old 07-16-2013, 11:29 PM Thread Starter
95YJMountie
95YJMountie's Avatar
Posted a thread a few weeks ago about painting my jeep, and wasnt sure if i wanted to keep the diamond plate or not. But i am now thinking of keeping it, but making it black instead. Thoughts or ideas greatly appreciated. Ill be stripping for paint by possibly this weekend. Want to paint it by the last weekend of july (in 2 weeks)
95YJMountie is offline
post #2 of 15 Old 07-16-2013, 11:35 PM Thread Starter
95YJMountie
Forgot the pics, sorry.
Its on the fenders, rockers, corners, and the tailgate. Im repainting it black, and thought about doing the diamond plate black also.
post #3 of 15 Old 07-16-2013, 11:38 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I have been recently turned on to powdercoating. Is that an option for the diamond plate?
Luck Favours The Prepared
Anticanman is offline
post #4 of 15 Old 07-17-2013, 08:47 AM Thread Starter
95YJMountie
I considered it but wasnt sure how well itll hold up on trails
post #5 of 15 Old 07-17-2013, 09:41 AM
SeanB95YJ
initially, a quality powder coat will be more chip/scratch resistant than a quality paint... problem is, when it DOES chip/scratch, it's a whole ton harder to touch up (properly) than paint is
that diamond plate is Aluminum.... whatever top coat you have done, make sure a good etching primer/sealer is used to prevent oxidation of the alum, and peeling/flaking of the paint
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #6 of 15 Old 07-17-2013, 09:58 AM
DirtKar
Maximum Effort
DirtKar's Avatar
Meh. I did an entire diatribe on this and went into Photobucket to grab a pic, I come back to this screen and its gone.
Yes, powder is substantially more durable.
Yes, powder loves to be on aluminum.
Yes, aluminum is tough to keep paint on for the reasons mentioned above.
Yes, if you do damage the PC finish you will likely live with it or squirt it with the closest paint finish.
PC after dealing with flaky paint on old aluminum corners...
YJOTM JULY 2014
DirtKar is offline
post #7 of 15 Old 07-17-2013, 09:59 AM
DirtKar
Maximum Effort
DirtKar's Avatar
Excellent is your answer, Sir.
YJOTM JULY 2014
DirtKar is offline
post #8 of 15 Old 07-17-2013, 10:09 AM
bchap05
I hate the diamond plate looks way to 90's for me. But that's just me. Looks better in black.
bchap05 is offline
post #9 of 15 Old 07-17-2013, 11:08 AM Thread Starter
95YJMountie
Well, with that being said, ive narrowed it down to either powdercoating or removing. What do you guys think would be best??
post #10 of 15 Old 07-17-2013, 11:11 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It's your jeep. Run what you want but if you're gonna do something, do it right or not at all.
post #11 of 15 Old 07-17-2013, 11:30 AM
DirtKar
Maximum Effort
DirtKar's Avatar
Originally Posted by anticanman View Post
it's your jeep. Run what you want but if you're gonna do something, do it right or do it again.
fify
YJOTM JULY 2014
DirtKar is offline
post #12 of 15 Old 07-18-2013, 08:46 AM
Kuntryboy816
Kuntryboy816's Avatar
Before you rule out painting it....
Powdercoating vs paint... BOTH are going to get chipped eventually. It's just a matter of time. Does it really matter which goes first? I think ease of maintenance rules out over durability. PC is hard to "patch up" when it does get damaged. Paint is easy to fix.
I had an ORFab swing out tire carrier that I bought used. The PC was all mangled up and rust was working its way in even under the PC. I thought the same of whether to re-PC or strip and paint it. I opted to paint it. Reason being that I could touch it up really quick and cheap when it got damaged and it would be cheaper in the long run. Well I stripped it down to bare metal and bought a good etching primer and 4 cans of Rustoleum Hammered Black. Primer went on and gave it a full 2 days to dry. Then I applied 3 coats of the Rustoleum. On the 4th coat I sprayed heavy and then used an old sponge to dab at it when it got tacky. It gave it an awesome textured finish. Finally I sprayed 2 coats of matte clear on it and it looked freaking sweet. When I sold it 2 years later, the guy asked me if it had even been used b/c it still looked new. BTW, I only used 1 can of primer, 2 cans of black and 1 can of clear when all was said and done... <$30.
If it were me, I'd keep the plate and maybe spray it with a dark gun-metal gray. That way it doesn't look like you just painted over it while it was on the Jeep and the different tone will set off the black paint nicely. Great thing is that you can choose whatever color you want and it's very easy to touch up when needed.
Shoot, I spraybombed my entire Jeep and it's held up great over the last couple years.
Originally Posted by 14Sport View Post
Until you know exactly what is underneath the, well, not really sure what to call them...mistakes...it's hard to come up with a plan of action.
Kuntryboy816 is offline
post #13 of 15 Old 07-18-2013, 10:52 AM Thread Starter
95YJMountie
Ill try it! Thanks man
post #14 of 15 Old 07-18-2013, 10:54 AM Thread Starter
95YJMountie
Good lookin jeep btw. I really like the camo
post #15 of 15 Old 07-19-2013, 12:49 PM
Kuntryboy816
Thanks!
