-   -   painting my yj (http://www.jeepforum.com/forum/f12/painting-my-yj-1505790/)
skimsurf 04-07-2013 07:21 PM
painting my yj
Since its getting warmer, and i have a bit of surface rust from the stupid brine they started using here in pa this past winter, im thinking about repainting my jeep. I dont know if you can tell from my profile pic, but theres no clear coat. It was just primer with a tan paint. this wont make it difficult to repaint, but I also dont want the same thing to happen again next winter. I was thinking about going flat black, but i kinda like the way it looks with the tan paint. downsides, i took it to the car wash and lots of paint came off, and of the course the resting, but it is just surface, so no body work. so without rhino/hercu lining the tub, or spending a fortune in a new paint job, what can i do myself to make the paint job look good, and be tough? i can deal with a few hundred bucks in paint. but any suggestions? I am going to wait till next month, when I am sure the whether will be good, as i dont have a garage, and or paint shop. just let me know what you think i should do. Thanks!
lestes94 04-07-2013 09:28 PM
I think that you have a good idea, but keep in mind that you are really going to get what you pay for. If you do something like rattle-can it, for example, you won't have UV protection and the paint won't last very long, or protect well from rust, essentially wasting your money. Also, a decent basecoat/ clearcoat job wil cost more than you are wanting to spend, but it will offer the protection that you need. If I were you I would either bump up the budget a little, or maybe even consider a single stage paint job, which will be cheaper than BC/CC, but will give you pretty much all of the benefits. Just my 2 cents.
crackedcornish 04-07-2013 09:43 PM
have you given any thought about using Monstaliner bedliner? It's available in something like 40 different colors now!
http://www.jeepforum.com/gallery/dat...a-emoticon.gif
http://www.jeepforum.com/forum/f43/i...-liner-875162/
go here to see the color chart
http://www.monstaliner.com/forms/monstaliner_colors.htm
SeanB95YJ 04-07-2013 09:46 PM
a gallon of Rust-Oleum in your favorite (available) color... a gallon of acetone... a 4" mini roller frame with a pack or two of the dense foam rollers... and a variety of grits wet/dry sandpaper. for about $50 and some time & elbow grease, you'll have a finish that can look really good, will greatly outlast any rattle-can finish, and super cheap to touch up if you need.
do some google image searching for roller paint car or similar... some incredible results are possible
crackedcornish 04-07-2013 10:07 PM
that's pretty much how I did mine...but if I had to do over, I think I would go Monsta now because of some of the newer colors
Rustoleum Safety Orange rolled over Duplicolor spray on bedliner
http://i151.photobucket.com/albums/s...h/f07ca66e.jpg
SeanB95YJ 04-07-2013 10:29 PM
I would've loved to do Monster in Suicide Blonde, but the majority of my current Jeep budget is being used gathering the final items for my upcoming swap.... and ~$50 for Rust-Oleum Safety Yellow, acetone, etc beat the $300+ it would've cost me to do the Monsta.
maybe a few years down the road I might
I just re-read the OP... he did mention not wanting to do Rhino/Herculiner... I assumed he'd consider Monsta along those same lines.
crackedcornish 04-08-2013 06:56 AM
I saw that too, but mentioned Monsta only because it's a tough, do it yourself coating that is available in many colors and has a decent texture for the interior/exterior surfaces of a Jeep. Unlike the Herc that is only available in a few basic colors and has a much coarser texture to it.
Or the Rhino which has to be applied professionally, and is a totally different type of product that costs some big $$, but it is superior to any D.I.Y. type stuff in the toughness/thickness categories as long as the guys doing the surface prep know what they are doing.
Like I said earlier I would have gone Monsta on mine, but when I started they didn't offer some of the more vibrant colors that they have now.
I really like the colors like Predator
http://www.monstaliner.com/images/co...or-150x150.jpg
and Apocalypse :D
http://www.monstaliner.com/images/co...se-150x150.jpg
Destr0 04-08-2013 09:35 AM
I painted mine with Rustoleum/Acetone mix and a cheap Harbor Freight HPLV gun. Worked great- if you have access to a big compressor I would go that route rather than all the elbow grease of the roll-on rustoleum.
I will be doing mine again this spring- I did a rush job and just scuffed and shot mine and I have some rust coming back through. This time I am going to kill all the rust first them paint.
GrantYJ 04-08-2013 10:25 AM
3 Attachment(s)
Rustoleum and Mineral Spirits rolled on with a 4" foam roller (lots of coats). If this method interests you at all, Google "$50 paint job". You'll find more information than you want. It's labor intensive, but it works very well. I did the headlight bucket on my motorcycle using this method (as a test before I did it to my Jeep). It's been on there for three or four years. I've sprayed it directly at the car wash on a very regular basis and there are no issues with it that I've found.
The first pic is when I started dissassembling after mock-up and body work. I've included this to give you an idea of how well it covers (I didn't prime it, I started rolling in the condition you see in the first pic). The second is a decent picture from yesterday afternoon during assembly (the nasty stuff on the side plate of my tube fender is just buffing compound, I hadn't cleaned it when I took the pic). The third is how it's sitting in the shop now, but the picture quality is poor (dark out + cell phone pic = crap picture). Once I get my rock sliders back on, I'll be in business.
Attachment 603554
Attachment 603555
Attachment 603556
I don't know a cheaper way to get a decent paint job than this. If you go this route, I suggest picking a color that's available in both cans and rattle cans.
Regardless of what you do, you're going to have to prep adequately (removing grease/wax and scuffing well enough for the paint to stick). If you don't do this, it doesn't matter how much you spend on paint, it won't last.
skimsurf 04-08-2013 10:38 AM
thanks for all the info. im going to look at the monsta liner and and the roll on method. thanks a lot. ill keep you guys posted on what i find.
The time now is 04:59 AM.
