#1 | |
Painting a hard top?
Can I rattle can my hard top or will it just come out looking like crap?
DINSTAAR |
#2 |
I used a foam roller and a pint of Rustoleum white high gloss enamel. Its oil based and takes a while to dry. It came out great and it was easy. The slight texture from the foam roller hides minor imperfections. Also a stronger finish than rattle can. Not a scratch yet
#3 |
what color was it when you started?
DINSTAAR |
#4 |
My top was black and changed to white. Everyone told me not do white until they saw the finished product. Now everyone loves it
#5 |
I rattle canned one flat black. It turned out great.
I also put Herculiner on my current top. It looks pretty good, too. |
#6 |
can you guys show me a pic?
DINSTAAR |
#7 |
rattle can flat scratches easy. how many cans did you use? i used 1 can of rusto to paint my top
#8 |
I tried rattle can, then wound up using herculiner. A friend used the roll on method. IMO, roll on looks better, Herculiner is tough, and really hides any imperfections.
95 YJ 8" of lift 36" Iroks, & more mods than I can really afford. The General Lee....YEEEEHAAWWW http://s488.photobucket.com/albums/rr249/jerseyjeep2003/General%20Jeep/?action=view¤t=trailride7-6-08105.jpg |
#9 |
how much is herculiner and where can i buy it?
DINSTAAR |
#10 |
you can order it off the net.... just google it
93 YJ, 4.0L, 5speed, 4" lift on 33x12.50x15 maxxis mudders, pacer steel wheels, custom front bumper, warn 10,000lb winch, lock rite lockers front/rear, 4.56 gears |
#11 |
herc for a hardtop = waste of money = serves no purpose
#12 |
Do I need to sand it first wether I herc it or paint it?
DINSTAAR |
#13 |
Ole Ironhead
I used Gator Gaurd II bedliner on mine..its a 2 part epoxy,much better than single stage ,holds better in UV and more durable and has a better bond.
60.00 a kit,can roll on or spray on with the shultz gun,the gun only costs 25.00 I have to disagree with herculiner or any good bedliners on a hardtop being useless,its much more durable when going through tree branches and bushes on the trails ,will last MUCH longer than any paint and gives it a vinyl look with the texture it gives.It also quiets down the outside noises and helps insulate. Useless?...FAR from it... |
#14 |
Ole Ironhead
#15 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
