Painting Engine block - JeepForum.com
post #1 of 5 Old 08-09-2013, 07:26 AM Thread Starter
thunderstar99
Okay, I just got my block back from the machine shop, baked, magna fluxed, bead blasted, bored out 40 over, crankshaft alignment, freeze plugs and camshaft bearing pressed in. I am now ready to paint the engine block. I was wondering if anyone had any good ideas on prepping the engine for paint and what type of paint to use.
thunderstar99 is offline
post #2 of 5 Old 08-09-2013, 07:59 AM
jokerchief462
Clean with a degreaser simple green or something similar. Mask off what you don't want painted. Auto parts stores have a specific spray paint for engines in many colors. Have some fun be creative with the colors. I went black no problems two coats. I also used an aluminum color on the intake trans and transfer case.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 5 Old 08-09-2013, 08:39 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Engine enamel comes in everything from rattlecan to a professional two stage setup for use in a gun.
Luck Favours The Prepared
Anticanman is offline
post #4 of 5 Old 08-09-2013, 11:44 AM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Attachment 655395
DO NOT USE SIMPLE GREEN to degrease just before painting. It will leave a residue that can allow your paint to bubble and peel. Go to a professional paint supply and buy a can of prep degreaser and cheesecloth. OR go to home depot and buy a can of MEK Substitute and lint-free microfiber cloths and wet the cloths with the MEK and wipe down your surface prior to painting. Let it dry completely before you start painting. I highly recommend using a "Direct to metal" primer or Self Etching Primer on any surface prior to rattle canning it.
80% of any paint jobs longevity is determined by the prep work. Don't skimp on the prep or you'll pay the price later.
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luuca is offline
post #5 of 5 Old 08-09-2013, 12:35 PM
Gage56
+1 Def us a etching primer and Pre Prep Cleaner First
1992 YJ
Gage56 is offline
