painting a bare steel bumper - JeepForum.com
post #1 of 20 Old 03-06-2009, 03:20 AM Thread Starter
JIBTEXHNKA
1987 YJ Wrangler
my shiny new bumper from jcr offroad just showed up! but the one thing i forgot about was that they ship them unpainted.
i know absolutely nothing about painting metal of any kind. so what do i do?
i just want the most durable black paint job possible. i don't want it to scratch off and start rusting the first time i hit a rock or something.
can i use bedliner on it? is there any good reason not to?
JIBTEXHNKA is offline
post #2 of 20 Old 03-06-2009, 03:51 AM
MYYJ93
I'd hit it with a few coats of good quality primer then use a good paint on bedliner. That stuff is pretty tough.
MYYJ93 is offline
post #3 of 20 Old 03-06-2009, 04:49 AM
lobukjeep
Sand it first.Acid etch primer(they actually sell it in a spray can).It'll give you some bite.I always use auto paint but that's kind of an overkill for a bumper.I'm sure some other guys have used some tough paint you can get cheaper.
"We don't call you son 'cause your bright"
lobukjeep is offline
post #4 of 20 Old 03-06-2009, 05:40 AM
ss454
+1..........
ss454 is offline
post #5 of 20 Old 03-06-2009, 06:40 AM
Burnerman
Burnerman's Avatar
Clean and prep the metal like posted above. I had some POR15 I used as a base coat and then used Duplicolor auto paint from Advance Auto. I sprayed it black and the Duplicolor paint goes on real nice. Very hard to mess it up. If it does get scratched or chipped $5 at Advance and I just touch it up.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #6 of 20 Old 03-06-2009, 07:10 AM
MJMPC
Have them powder coated..........
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #7 of 20 Old 03-06-2009, 07:20 AM
Burnerman
Burnerman's Avatar
I have yet to see powder coating hold up. There maybe some people that can do it right but I've never seen it. Everything I've run into has sheets of powder coat peeling off rusty metal. I spent maybe $40 on paint and prep materials for my bumper. I don't think a properly done powder coat job would be that cheap...
96 ZJ.
post #8 of 20 Old 03-06-2009, 07:28 AM
Cobra Jeep
Since no one else has mentioned it. Go buy a big can of acetone, some rags, and some chemical resistant gloves. Once you get done sanding the bumper lightly, clean the crap out of it with the acetone. Put on the cloves (cause its rough on hands) and pour some on the rag and wipe it all down several times untill you can wipe it with a clean rang and you get no crud on it. Also, make sure you do this OUTSIDE. The fumes are kinda rough. But makeing sure the metal is super clean like this before you paint will make all the diffrence. The metal has to be clean of all crud, oil, dirt, etc.... Otherwise the paint wont stick very good and will flake off easy, it if even sticks at all.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #9 of 20 Old 03-06-2009, 07:37 AM
lonestar_yj
i just built bumpers front and rear. I just rattle can primered them and then rattle can black rustoleum.
93 wrangler sahara, 4" lift, 1" shackles, 33x12.5 maxis buckshots on crager rims, hm front,back bumper,towbar, hand throttle
lonestar_yj is offline
post #10 of 20 Old 03-06-2009, 12:25 PM
timatoe
timatoe's Avatar
That's what I did too, I did usse the "self etching" primer though.
timatoe is offline
post #11 of 20 Old 03-06-2009, 12:28 PM
Exparrot
Exparrot's Avatar
I highly recommend Rustoleum Professional. It's tough, dries quick, and comes in flat or gloss.
My front bumper has taken a beating and it only has one or two scratches that I'm too lazy to get out there and touch up. Rocker guards, rear bumper and wheels look like I painted them yesterday...
I got a Jeep, it's lifted and it's got crap bolted to it.
Color by Rattle-Can.
LO Jeep Club #111 [and not proud of it]
Red Jeep Club #MC399
Exparrot is offline
post #12 of 20 Old 03-06-2009, 12:42 PM
admisgd
admisgd's Avatar
2016 JK Wrangler
I used Duplicolor spray on bedliner directly on the bare metal of the bumper. I prepped the bare metal well but wish I had used a primer coat. The bedliner peels pretty easy when it gets bumped and I can see a few small rust spots. It is easy to patch because I just carry a can of duplicolor spray with me, but if I had to do it all over again I would have used a primer coat first.
93 YJ Renegade, I6, 4" RC Lift, K&N intake, Tuffy Trunk & Console, 10k lb Winch, Dana 30 Assuie Locker
admisgd is offline
post #13 of 20 Old 03-06-2009, 12:55 PM Thread Starter
JIBTEXHNKA
1987 YJ Wrangler
so, with self-etching primer there is no need to sand?
and what's the best way to support the thing while painting... like, to set it somewhere where i can paint all of it at once. or is that too much to ask for? thanks for all the help so far.
post #14 of 20 Old 03-06-2009, 01:15 PM
chadroc
I don't know the answer to the primer, but i have a hook in the ceiling in my garage. I hang everything I paint buy a nylon strap that has hooks on each end. That works pretty nice.
I use plasticote bedliner spray. It's not that hard to scratch, but easy to fix. It has to go on bare medal or original paint. Every other paint I've tried to put it over bubbles up
chadroc is offline
post #15 of 20 Old 03-06-2009, 01:38 PM
Jeepsr4me19
1976 CJ5
The first thing you do is CLEAN it, get all the oil and metal protective coating off it. If you sand it 1st you will drive that stuff into the metal and it is a pain to clean later. And the paint will never stick. But after cleaning just prime with a good bare metal primer and cover it with either bed liner or a good enamel paint.
Jeepsr4me19 is offline
Re-painting used doors... bare metal under hinge? Burlbook48 YJ Wrangler Technical Forum 9 05-12-2009 08:16 PM
Have paint question for bare steel imustbenuts TJ Wrangler Technical Forum 12 05-06-2009 07:20 AM
What do people use to paint bare steel bumpers? RVA_TJ06 Wrangler General Discussion 7 11-09-2008 05:48 PM
How should I paint my bare steel bumper? BaldHeadedDawg TJ Wrangler Technical Forum 16 08-07-2008 06:19 PM
Painting bare steel bumpers neilmo81 TJ Wrangler Technical Forum 19 11-03-2007 01:29 PM
