Oxygen Sensor question - JeepForum.com
post #1 of 4 Old 02-22-2007, 04:53 PM Thread Starter
Grape Ape
Web Wanker
Grape Ape's Avatar
I have a 92 YJ with a 4.0 automatic.
I got a check engine light code yesterday. Checked the codes and it is 21 (O2S stays at center or O2S shorted to voltage). No problem I can fix it.
The question I have is what does that cause in the engine? I have very little knowledge regarding fuel issues (IE: How a vehicle runs when lean, rich, etc...) The reason I ask what it causes is that I only drove it a little yesterday when I noticed the CEL today, I ran to the store and noticed that my jeep is quite a bit peppier. I stomp on it and she responds, much better than just the other day when I was out playing.
Is that due to something regarding the fuel and O2 sensor? Or is it something else and the O2 sensor just happened to crap out at this time?
EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun!
We've idiot proofed the world... now its full of idiots. - Spiritof76
You will truly be the same today as you will be five years from now, except for two things, the people you meet and the books you read. Charles E. Jones
I think I'll add some memorable quotes. blah blah blah..... FPKites
Trying to understand some people, is like trying to pick up a turd by the clean side.
Grape Ape is offline
post #2 of 4 Old 02-22-2007, 05:30 PM
witchy woman
The control module reads the exhaust via the O2 sensor and adjusts the mixture/fuel rate accordingly. They do wear out. I replaced one on my wife's van recently and it runs much better. Uses substantially less gas with a functioning sensor. It's just part of the whole ignition/fuel control sensor array. Your sensor may have been giving a false reading that made the engine run sluggishly.
***The early bird gets the worm, but the second mouse gets the cheese.***
witchy woman is offline
post #3 of 4 Old 02-22-2007, 07:41 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
If it's original it prolly wore out. The ethinol(sp?) for winter gas grades nowadays is really hard on them.
- Ernie
Richmond88yj is offline
post #4 of 4 Old 02-22-2007, 08:30 PM
YJ_
YJ_'s Avatar
Mine crap'd out a while ago and I just got around to replacing it last weekend... It runs slightly better (no sputtering at highway speeds) and uses a bit less gas... I think I got a few extra miles out of the Heep when I filled up today...
"if ya can't duct it **** it"
[] IIIII []
YJ_ is offline
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction. blackattak TJ Wrangler Technical Forum 4 02-28-2011 04:20 PM
Bank 2, Sensor 2 oxygen sensor... Alexia TJ Wrangler Technical Forum 2 09-19-2009 01:29 PM
oxygen sensor question.. gene97sport TJ Wrangler Technical Forum 15 04-22-2009 04:55 PM
Oxygen Sensor Problem / Question jeep11484 TJ Wrangler Technical Forum 7 03-18-2009 06:38 AM
Oxygen Sensor Problem / Question jeep11484 TJ Wrangler Technical Forum 0 03-17-2009 06:35 PM
