oxygen sensor question - Page 2 - JeepForum.com
post #16 of 21 Old 03-29-2010, 01:48 PM Thread Starter
metalroses
Originally Posted by Que89YJ View Post
If I am understanding you, the Jeep has an unsteady idle where its shifting up and downn RPM constantly and a stall as well? I know you said you check for a vacuum leak, did you check with starter fluid or brake cleaner. Could you have a problem with the carb? How long after you did the Nutter and team Rush mods did you start to have the problem?
ive started to have this problem since ive changed the o2 sensor, oh wait i installed a new diagraphm accelerator pump..... but i don't think this is the problem. starter fluid? i dont think that should be the problem since this happened afer ive changed de sensor.
metalroses is offline
post #17 of 21 Old 03-29-2010, 01:55 PM
Burnerman
Burnerman's Avatar
i installed a new diaphram accelerator pump..... but i don't think this is the problem.
You installed the accelerator pump plunger in the carb? If it just stalls out when idling down the idle tubes are clogged. Carters have issues with the idle tubes and any disturbance in the fuel system can clog the tubes up. tiny bit of rust, dirt,anything get up into the tubes and then you have no idle.>http://home.sprynet.com/~dale02/idle.htm
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #18 of 21 Old 03-29-2010, 02:12 PM Thread Starter
metalroses
ok i have the mc2100 carb and after the new acc pump the jeep was good but i changed it because it was stalling when i accelerated fast. but ill chek that cause it can be applied too for this carb
post #19 of 21 Old 03-29-2010, 03:06 PM
Que89YJ
It makes more sense. The starter fluid or brake cleaner can be sprayed lightly around the engine compartment to look for a change in idle from a vacuum leak.
Que89YJ is offline
post #20 of 21 Old 04-02-2010, 07:23 PM Thread Starter
metalroses
ive did everything and nothing! im so lucky with this carb engine haahah!
post #21 of 21 Old 04-03-2010, 01:55 PM Thread Starter
metalroses
the idle tubes of the mc2100 are inside the buster venturi?
Very confused! banck two sensor two oxygen sensor imnotaniceboy TJ Wrangler Technical Forum 5 03-12-2010 04:22 AM
oxygen sensor question.. gene97sport TJ Wrangler Technical Forum 15 04-22-2009 04:55 PM
Oxygen Sensor Problem / Question jeep11484 TJ Wrangler Technical Forum 7 03-18-2009 06:38 AM
Oxygen Sensor Problem / Question jeep11484 TJ Wrangler Technical Forum 0 03-17-2009 06:35 PM
Oxygen Sensor question Grape Ape YJ Wrangler Technical Forum 3 02-22-2007 08:30 PM
