Overpriced Mechanic Help! - JeepForum.com
post #1 of 19 Old 05-31-2013, 11:07 AM Thread Starter
Razorback23
I took the Wrangler (4.0 6cyl 1995) to the mechanic the other day to see what all needed fixed on my oil pan. He's a family friend so there isn't any ripping off, other than the labor costs! I knew the oil pan was leaking and needed fixed and my rear U-Joint was going out. Here is the following statement on the repairs. Tell me what you guys think. I think its really overpriced.
Labor
Oil Pan Gasket - 210.00
Valve Cover Gasket - 75.00
U-Joint - 75.00
Parts
Valve Cover - 48.81
Oil Pan Gasket - 28.87
U-Joint - 28.00
Ive found all the prices for the parts that I need to do it myself. I just cant find a valve cover gasket. Again its a 1995 4.0 6cyl
Razorback23 is offline
post #2 of 19 Old 05-31-2013, 11:13 AM
grandboost98
I guess it depends on where youre from. Around here, if you were to actually take it to a garage, average mechanic gets paid $95 an hour so 75 isnt bad although everything there is pretty simple to do yourself with basic tools. And the parts, again, depends on what brands you go with. The valve cover gasket is like $15 from Qtec, valve cover around $45 and depending if you go with a spicer u joint or a whatever name u joint will determine that price.
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #3 of 19 Old 05-31-2013, 11:14 AM
Firefyter-Emt
Honestly, for a "shop price"... that is very fair. That's a hair over 4 hours at $50 for the oil pan (and that is a very low rate) and an 1.5 for the u-joint and valve cover gasket. That a tad high @ $50.00, but low if the hourly rate in your area is closer to $75-$100 or so.
If you can do it yourself, you save all of that money... so no worries!
Firefyter-Emt is offline
post #4 of 19 Old 05-31-2013, 11:31 AM
jumbojeepman
1976 CJ7
The average mechanic makes far less than the rate you are quoting. The average shop may charge $95/hr, but the mechanic gets a much less.
jumbojeepman is offline
post #5 of 19 Old 05-31-2013, 11:32 AM
Michaelgoesrawr
Personally I'd do the u joint and valve cover( I recommend a fel pro blue permatex gasket) if you can find it. I've never done an oil pan gasket but have one in the wings for our Comanche.
Michaelgoesrawr is offline
post #6 of 19 Old 05-31-2013, 11:53 AM
grandboost98
You get the point....If you were to take it to a garage to be fixed, youre paying x amount of money. Where or who that money goes and how its split up afterwards is not the customers problem
post #7 of 19 Old 05-31-2013, 11:54 AM
grandboost98
x2
It should take you less than an hour to do both of them
post #8 of 19 Old 05-31-2013, 12:08 PM
Old4X
1990 CJ7
The oil pan is a snap. It just drops straight down, nothing to remove like cross over members, supports, etc.
Get an electric nut driver and you can have it off in less then 15 minutes. Just remember to put a dab of RTV in the corners by the crank before reinstall.
Mechanics need to make a living too. And running/owning a shop is very expensive. You are paying for all of this when you take your heep to a commercial shop or mechanic.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #9 of 19 Old 05-31-2013, 12:27 PM
roadyrob
1987 YJ Wrangler
I think the prices are pretty high but I do most of my own repairs so I'm out of touch with what a shop is charging. everything listed is easy to do and if you have never done it before a great learning experience.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #10 of 19 Old 05-31-2013, 03:13 PM
dancytron
Most mechanics charge "out of the book". So if "the book" says "valve cover remove and replace 1 hour" then they are going to charge you an hour whether it takes 10 minutes or 3 hours. You should ask them if they are charging you out of the book and if the answer is yes, then they should show it to you and explain how they used it to to calculate the estimate.
If any mechanic won't show you "the book" (and some won't), then go somewhere else.
Of course, "the book" is on a computer at this point, not an actual book.
dancytron is online now
post #11 of 19 Old 05-31-2013, 04:54 PM
bill8bud
Sounds fair to me.
You can spend the money on tools to do the job and reuse those tools on future jobs
Or you can pay someone to do the work. I will be honest sometimes I get into projects I wish I would have sent out to the mechanic. With the help of this forum you can save a lot of money on shop bills and you will have a better understanding of how your jeep works. This way when it fails on a trail you have a chance.
bill8bud is offline
post #12 of 19 Old 06-01-2013, 12:07 AM
ROTTEN
$75 for that ujoint is fair to me. Considering getting that hub off yourself might be a Pita.
Id do the valve cover myself. Thats right there and not awkward.
Some advice I can offer is havd him do the rear main seal if you have him do the oil pan
I'm new
ROTTEN is offline
post #13 of 19 Old 06-01-2013, 12:35 AM
ltrail
1984 XJ Cherokee
all true. Remember most of get paid flat rate. So that hour for the oil pan that only takes 10min will even out when the next job comes along and pays 1hr and takes the whole hour or more. Never had a problem showing customers the labor times. Our labor rate is 85, or a tad lower(seniors/military). $100 for a u-joint replaced is a little stiff, i don't think they near an hour.
Rotten, i hope you aren't removing hubs to replace a rear u-joint.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #14 of 19 Old 06-01-2013, 01:16 AM
ROTTEN
Oh!Lol!
I should use my reading skills better
Yeah that ujoint is the same as the valve cover. Right there and accessible
Now on the other hand if its $75 for a front ujoint id take that deal
I'm new
ROTTEN is offline
post #15 of 19 Old 06-01-2013, 06:19 AM
RustedWrangler
Labor
U-Joint - 75.00
Parts
Valve Cover - 48.81
U-Joint - 28.00
www.rockauto.com
www.RCPFA.com
RustedWrangler is offline
