Overheating problem - JeepForum.com
post #1 of 7 Old 08-25-2011, 08:19 PM Thread Starter
Shellb2414
Overheating problem
OK so a friend of mine has a 91 YJ and it started making an clanking noise for lack of a better term a few months ago it only seemed to happen when the gas is pressed down...let off on the gas and it stops...we are still beginners at trying to work on our Jeeps so we took it to the shop to figure out what it was so we could learn how to fix it....well they didnt know but while it was raised it was dripping water...i asked what it was the guy said its the A/C well der we dont even have A/C. so then it has since over heated a couple times. In the last couple of weeks once we turned it off you could here water dripping on to something and making the sizzling steam sound. It had stalled out, gas guage is messed up, thought it was out of gas, turns out it wasnt and had really just stalled out. Filled it up made it about 1/2 a mile and it started to just over heat temp guage was off the charts and pressing gas pedal all the way down it would get slower and slower but we were just trying to make it off the road. This time the coolant resevoir wasnt empty...water was still in it and boiling and smoke was coming from the engine. This time its yet to crank back up...just almost cranks but cant quite make it. We have been coming to this site since we got out Jeeps and have learned so much from all the incredibly helpful people and I appreciate it. I hope someone knows what this might be. Any ideas at all? Thanks!
Shellb2414 is offline
post #2 of 7 Old 08-26-2011, 06:48 AM
Que89YJ
The fact that you kept driving it when it was overheating is bad news. These motors are pretty durable but cooling is very important. The noise you heard when you were accelerating could have been preignition know because it was running hotter then it should have been or the water pump. Check the oil and see if it has become milky. If you are lucky you might have only blown a head gasket or cracked the head. You probably had a bad water pump or radiator.
Que89YJ is offline
post #3 of 7 Old 08-26-2011, 07:17 AM
Andywear
If its still all stock its time to change the water pump, rad and thermo.
But if he blew a gasket...... O boy.
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #4 of 7 Old 08-26-2011, 07:44 AM
nembudonna
Sounds like you might have blown a head gasket. Not a real hard thing to fix. Check to see if you have compression.
nembudonna is offline
post #5 of 7 Old 08-26-2011, 04:41 PM Thread Starter
Shellb2414
what does the milky oil mean?
post #6 of 7 Old 08-26-2011, 04:42 PM Thread Starter
Shellb2414
and how can we check to see about compression? thanks so much for the info!
post #7 of 7 Old 08-26-2011, 06:33 PM
oldtime_ironman
The milky oil would be a blown head gasket or a cracked block/head. It means "don't drive it at all till its fixed".
You can check the compression with a compression tester, available at most any auto parts store. The compression test will also tell you a lot about the internal condition of the engine.
Either way, its a miracle that it held together so far. You are more than likely looking at doing some real work on it.
oldtime_ironman is offline
Overheating problem chadsmeltzer TJ Wrangler Technical Forum 28 08-18-2010 04:48 AM
4.0L overheating problem crb577 YJ Wrangler Technical Forum 89 11-09-2009 07:21 AM
Overheating problem Daylan YJ Wrangler Technical Forum 1 09-16-2007 02:05 PM
Overheating problem bwp262 TJ Wrangler Technical Forum 4 11-20-2006 12:27 PM
overheating problem Grow TJ Wrangler Technical Forum 1 08-31-2004 01:05 PM
