Overheating issue on my yj - radiator? - Page 2 - JeepForum.com
post #16 of 22 Old 12-15-2011, 06:24 PM Thread Starter
matrix311
ok so I bought a new fan clutch just a moment ago. I'm going to install it tonight and hope this does the trick. Wish me luck and cross your fingers!
Eric - *'92 White YJ, 4.5" custom Deaver springs, 35" MTRs, Tera-Low 4:1, CAI, Rear 8.8, Chromo D30, 4.88s, locked front/rear, full cage and front/rear tube fenders.
*'08 Silver Rubicon JKU 2.5" lift, 5.13's and 35's
matrix311 is offline
post #17 of 22 Old 12-15-2011, 07:30 PM
superj
the fan clutch has no effect while you are driving. if it heats up while driving and cools while sitting, your radiator is bad.
edit, not so much bad as plugged
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #18 of 22 Old 12-15-2011, 07:45 PM Thread Starter
matrix311
Either way the part has been replaced. My fan clutch had oil coming out the front. If it still overheats I will replace the radiator.
post #19 of 22 Old 12-16-2011, 05:52 AM
Que89YJ
Hey Matrix. Look at the Taurus fan Mod when you get a chance. Yes, the clutch for the fan is important while sitting and moving below 30Mph. That fan is the primary air mover. Keep us posted.
Que89YJ is offline
post #20 of 22 Old 12-16-2011, 04:44 PM
duzie
did you check to see if p.o. replaced the water pump with the correct one counter clockwise rotation for serpentine belt clockwise with v belt
duzie is offline
post #21 of 22 Old 12-17-2011, 12:19 AM Thread Starter
matrix311
Well I just sold my old wheels that were on the Jeep lastnight so today I bought new struts, new radiator, new water pump and new brake pads today. The old Jeep is going to be happy once i'm done putting all these new parts on her. Hopefully between a new radiator, new coolant temp sensor, new clutch fan, new water pump, new coolant and a new failsafe thermostat my Jeep will no longer overheat and run cool and efficient. I'm about half way done installing all the cooling system stuff and going to call it a night. I will be back at it bright and early tomorrow and crossing my fingers this does the trick!
post #22 of 22 Old 12-17-2011, 11:01 AM
spshultz
1987 YJ Wrangler
You might check to see if the lower radiator hose has a spring in it to keep it from collapsing. My 4.2 has a spring but I don't know if the 2.5's would have it.
spshultz is offline
New Radiator Overheating JustChillin TJ Wrangler Technical Forum 7 08-21-2011 09:40 PM
Radiator overheating mickeyd699 TJ Wrangler Technical Forum 2 06-14-2011 01:00 PM
overheating, no heat, cracked radiator jeffp2152 YJ Wrangler Technical Forum 6 12-21-2010 04:51 PM
2002 TJ Overheating, radiator ideas? River TJ Wrangler Technical Forum 8 07-11-2009 04:44 PM
Radiator/ engine overheating Shane64 TJ Wrangler Technical Forum 21 05-21-2008 06:13 AM
