Overheating at highway speeds - JeepForum.com
post #1 of 17 Old 11-03-2013, 10:20 PM Thread Starter
jared-f
So my 89 4.2 only starts overheating on the highway at RPMs over 1600. Was running 1700-1900 the other day and it overheated in about 10 miles. I drive in the city everyday at around 1500 RPMs and no problems. Just did a tune up, new distributor, radiator, new carb(mc2150). Any ideas that might solve my problem?
jared-f is offline
post #2 of 17 Old 11-03-2013, 10:26 PM
Xpress
My initial assumptions are the waterpump.... Does it overheat at idle? Putting around on the trails?
All about that unibody life.
Xpress is offline
post #3 of 17 Old 11-03-2013, 10:30 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Did you replace the radiator cap ? When you replaced the radiator. How about the Thermostat ? At hiway speeds you should have enough air keeping it cool. Mine runs at 175 on the hiway. Did you get all of the air out of the system ? Any seepage around the waterpump?
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #4 of 17 Old 11-03-2013, 10:33 PM
Xpress
Also does your thermostat have a tiny weep hole in it? The weep hole is essential to allowing air to properly bleed out of the system, otherwise air will be trapped behind the thermostat, which will prevent it from opening.
Xpress is offline
post #5 of 17 Old 11-03-2013, 10:47 PM
Chrisnvegas
Chrisnvegas's Avatar
Cheap t stats often do not open enough to cool at highway speeds. Is it possible during gasket scraping some debris could have gotten into the block? This could also restrict flow through the t stat.
And as mentioned above, a weak radiator cap spring can allow the coolant to turn into steam.
I know people will disagree, but a properly functioning fan is essential. Especially during highway driving where the engine is creating much heat trying to move all the air.
When you refill the cooling system, remove the heater hose from the t-stat. It will fill nicely and get most of the air out. And if you switched to an aluminum radiator from the original brass and it has plastic tanks, you just reduced the cooling by as much as 30%. The brass tanks in the original really add to the cooling. Plastic tanks do not transfer much heat.
BAN COMPUTER UPDATES!
Chrisnvegas is online now
post #6 of 17 Old 11-04-2013, 06:16 AM
crackedcornish
besides making sure there is no air in your cooling system, with a new distributor and carb installed I'd pull the spark plugs and see what they are telling you too..
you may be leaning out and running hotter at higher rpm's
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is online now
post #7 of 17 Old 11-04-2013, 09:04 AM Thread Starter
jared-f
That's my thought too, so I'll be taking a look at that this weekend. No overheating at idle or on the trails. Just when its consistently running over 1600 RPMs
jared-f is offline
post #8 of 17 Old 11-04-2013, 09:32 AM
crackedcornish
come to think of it, didn't the 4.2's come with either v-belts or serpentine belts and have different rotations on the pump depending on the belt system used?
make sure you have the correct pump..I think the serpentine belt set up used a reverse rotation pump
post #9 of 17 Old 11-04-2013, 10:26 AM
Tom95YJ
Tom95YJ's Avatar
They both spin the same direction with Serp and V configuration
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #10 of 17 Old 11-04-2013, 01:19 PM
crackedcornish
is it the 4.0L or the 2.5L that have reverse direction then?...I've heard there are Jeeps that use a reverse direction pump on them, and that they have an "R" cast into them to signify that they are in fact a reverse direction pump.
post #11 of 17 Old 11-04-2013, 01:28 PM
Reno72
4.0 with serpentine is reverse rotation. It's stamped "R" on the impeller or body.
Reno72 is offline
post #12 of 17 Old 11-04-2013, 02:21 PM
Tom95YJ
Tom95YJ's Avatar
Op would have the 4.2
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #13 of 17 Old 11-04-2013, 03:11 PM
roadyrob
1987 YJ Wrangler
no, the v belt is standard rotation and the serpentine is reverse.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #14 of 17 Old 11-04-2013, 03:23 PM
Tom95YJ
Tom95YJ's Avatar
The belts are driven off the crank. I am pretty sure the direction of the crankshaft rotation has never Reversed.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #15 of 17 Old 11-04-2013, 03:46 PM
roadyrob
1987 YJ Wrangler
your of course correct, the engines all rotate in the same direction but the belt configuration is different. I just changed my waterpump about 3 weeks ago, they show 2 different pumps for the 4.2. standard rotation for v belts, reverse for serpentine.
roadyrob is offline
