Quantcast Overheating - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Overheating
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 03-12-2008, 10:07 AM   #1
jlsporty
Overheating
I have a 95 YJ 4.0 5spd and on my way to work this morning I noticed my temp was bouncing between 190ish (normal operating temp) to 220-230. It would heat up then drop back down to the normal 190ish temp. I stopped and put about 1/3 of a gallon of anti freeze in the radiator thinking that maybe since the coolent was low that could be causing the problem. However after that the same thing continued to happen. It doesn't matter if I'm stopped at a light or cruizing at 65 on the highway the same behavior happens. Does anybody have any ideas? I'm doubtful it's a thermostat because it seems to be opening up when the temp gets hot.
Any thoughts/suggestions are greatly appreciated.
Jason
"No more wishing I'd drank that Beer, smoked that bowl, or punched that guy. It's all gonna be balls-out from now on. I'm gonna do all I can to really make the most out of every day. "Live it to the max" is my other new motto, and I'm gonna start by getting drunk tonight. That'll be sweet."
jlsporty is offline   Reply With Quote
Old 03-12-2008, 10:10 AM   #2
70sElvis
Could still be the thermostat. Maybe it is just sticking a little.
70sElvis is offline   Reply With Quote
Old 03-12-2008, 10:16 AM   #3
YJGEEWA
Fan clutch when it's warm at idle can you stop the fan with a piece of card board if so the fan clutch is bad? Water pump is it weeping little drips after you have let it sit for awhile? Or you could pressure test the system and see if you have a leak. Why did you have to add atifreeze?, that could be a good clue there.
Even a fish wouldn't get into trouble if he kept his mouth shut.
YJGEEWA is offline   Reply With Quote
Old 03-12-2008, 10:30 AM   #4
jlsporty
YJGEEWA, I have noticed a few drips here and there coming from what I thought was my lower radiator hose (didn't inspect much because of the little amount of leakage). I haven't checked the levels for quite some time and I sometimes smell a little antifreeze in the garage from time to time but don't see anything on the floor so I figured the cap was leaking a little or something. I may just go with changing the water pump I was going to flush the system but wanted to wait until my leak was fixed. I haven't changed one in years and that was on a small block chevy. Is it pretty simple on the 4.0 liter? I haven't looked too closely... I'm sure I can do it as I just replaced the clutch 5-6 months ago but just want to know what I'm in for.
Old 03-12-2008, 11:28 AM   #5
YJGEEWA
If you replaced the clutch I think the water pump should be sucker shot for ya. Just be careful when you buy it to match it up with the old one for ease of installation. Napa has reman # 58448, new # 42005, or 557136 they range from about $42. to $67. In my area.
Old 03-12-2008, 01:39 PM   #6
jlsporty
I think I'll give it a try since it's leaking down there I figure I can't do anything but help the situation. Thanks for the advice guys...
Old 03-12-2008, 01:51 PM   #7
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Tis your water pump. While you are in there, get a new thermostat anyway. Only an extra $6. Get a 195* therm and don't let anyone tell you otherwise. That is the stock therm.
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Glock Forum
