overheating - JeepForum.com
post #1 of 4 Old 10-23-2002, 05:50 PM Thread Starter
BPAGS11
overheating
I have an 89' 2.5, and lately after driving it for the day it's been overheating. It runs fine all day at around 185, then all of the sudden it spikes and overheats. Is this my water pump or my
t-stat?? Any info would help. THANKS
BPAGS11 is offline
post #2 of 4 Old 10-23-2002, 05:59 PM
SeaBee
SeaBee's Avatar
Make sure coolant level is ok first. It sounds like a sticking t-stat. Those are easy to replace. If that does not fix it, I think it would be a gage or sending unit problem. Try tapping on the gage (slim, I know) You might also try putting the heater on full blast, that should cool it down some. I really doubt that it's a water pump. It wouls likely o/h all the time plus it usually makes noise or leaks visibly. Oh, you might double check that you don't have coolant in your oil (milky) just to be safe. Hope this gives you a start.
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf" -George Orwell
SeaBee is offline
post #3 of 4 Old 10-23-2002, 07:06 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
It spikes? You mean the gauge bounces from average to full hot really quickly? Its the guage then, or a wire, or the sending unit ..
If it actually tries to boil over, then I would look at the water pump or the t-stat first ..
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #4 of 4 Old 10-23-2002, 09:02 PM
LoOpY
a coolant flush may also be in order. hows your radiator look? like a puzzle with a few missing peices, or is it all still there?
LoOpY is offline
overheating? attackcammel TJ Wrangler Technical Forum 7 07-04-2010 11:58 AM
overheating? Mudzilla6661 Wrangler General Discussion 8 08-15-2009 08:33 PM
overheating 87 danthman YJ Wrangler Technical Forum 6 03-05-2009 06:44 AM
overheating, only at 55+mph ...? TXjeepTJ TJ Wrangler Technical Forum 7 09-19-2007 07:55 AM
Overheating Kel Dub TJ Wrangler Technical Forum 7 01-21-2006 02:25 PM
