Overheating - Page 3 - JeepForum.com
post #31 of 70 Old 09-17-2013, 04:09 PM Thread Starter
cgcarpenter
Originally Posted by Rproject
If you have a serpentine belt, you have a reverse rotation water pump.
If you have v-belts, you have a standard rotation water pump.
Same for fan clutch too?
cgcarpenter is offline
post #32 of 70 Old 09-17-2013, 04:12 PM
Rproject
1987 YJ Wrangler
Yup. Just replaced mine last weekend.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #33 of 70 Old 09-17-2013, 04:18 PM Thread Starter
cgcarpenter
Cool thanks
post #34 of 70 Old 09-18-2013, 08:01 PM Thread Starter
cgcarpenter
Okay. So I replaced tstat, and clutch fan today. Checked to make sure the water pump is reverse rotation. It is indeed correct.
And flushed the radiator.
I can see the coolant moving through with the cap off.
It's was running at correct temp on the freeway and didn't jump to 240 as soon as I got off which is good.
BUT driving on the streets in stop and go traffic it would creep up to about 235 while stopped at stop lights and would drop 5-10 degrees until I hit the next light.
Question is. Would having no fan shroud really make it heat up this much?
Or are there any other suggestions?
Everything is new except the radiator.
post #35 of 70 Old 09-18-2013, 08:05 PM
Que89YJ
Check the resistance on the sensor for the temp. Yes, slow speed is when the shroud makes a difference. You can look at doing the Taurus rad fan mod. As I mentioned before pressure test the coolant system. Replace the radiator cap.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is online now
post #36 of 70 Old 09-18-2013, 08:16 PM Thread Starter
cgcarpenter
I did the radiator cap as well I forgot to mention.
Would running some of that flush fluids from autozone be a good idea?
Otherwise I'll try to get my hands on a fan shroud and go from there. It's not my jeep so I don't want to modify it to much.
post #37 of 70 Old 09-18-2013, 09:34 PM
Que89YJ
The fan and controller and fan is less then 100 but you shouldn't go there until you fix the problem at hand. Fan shoud and pressure test the system. If you have a meter you can check the sensor.
Fault codes:
No Start:
post #38 of 70 Old 09-18-2013, 09:46 PM Thread Starter
cgcarpenter
Yeah I'll pull the sensor and bring it to my electrical class and try to find a shroud this weekend and possibly pressure test it on Friday.
Thanks for the assistance guys. Much appreciated.
post #39 of 70 Old 09-18-2013, 10:40 PM
jsawduste
2006 YJ Wrangler
Yup, the fan is pulling air from the path of least résistance. Which is not necessary through your radiator.
jsawduste is offline
post #40 of 70 Old 09-18-2013, 11:19 PM
jokerchief462
If a stock shroud is not handy there was someone who made a custom shroud from a plastic trash can. Just pick the right size area some rivets and spare aluminum to mount it.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #41 of 70 Old 09-19-2013, 12:19 PM Thread Starter
cgcarpenter
So how bad is it that when we turn the jeep off the temp will go to about 220 after just street driving or about 240 when shutting it off after a considerable amount of freeway driving?
I believe someone called it thermal flush earlier.
Is the anyway to to help/prevent this?
post #42 of 70 Old 09-19-2013, 12:29 PM
Rproject
1987 YJ Wrangler
Have you flushed the system yet? Have you tried cleaning your radiator?
I was having the same nightmare time as you, keeping the temps down, for almost a month after a trip to Drummond Island. I cleaned the outside of the radiator with Simple Green and a power washer and did a system flush and refill. Now I'm lucky to get my gauge up to 180, and I haven't had a shroud on my fan for almost a year. neither does my son's ZJ and he's never had an overheating problem.
1996 White ZJ
Rproject is offline
post #43 of 70 Old 09-19-2013, 12:37 PM Thread Starter
cgcarpenter
Have you flushed the system yet? Have you tried cleaning your radiator? I was having the same nightmare time as you, keeping the temps down, for almost a month after a trip to Drummond Island. I cleaned the outside of the radiator with Simple Green and a power washer and did a system flush and refill. Now I'm lucky to get my gauge up to 180, and I haven't had a shroud on my fan for almost a year. neither does my son's ZJ and he's never had an overheating problem.
Yes I have. Temps stay down now unless traffic is very bad it'll creep up very slowly.
I'm talking about after I turn the jeep off it gets hot and I was just wondering how bad that could be.
post #44 of 70 Old 09-19-2013, 12:47 PM
Rproject
1987 YJ Wrangler
After you turn it off, the hot coolant from the engine is flowing back into the radiator. As it is, IMHO, you're still high. You're getting good flow, you have a new t-stat and the proper water pump, you've flushed the system. Something is not cooling the coolant that is flowing. On the highway, or anything over 35mph, the air being drawn across the radiator is enough to keep the coolant cool. At this point, I'm really leaning into the radiator being the source of your problems.
1996 White ZJ
Rproject is offline
post #45 of 70 Old 09-19-2013, 01:23 PM Thread Starter
cgcarpenter
That doesn't make sense. Why would the hot coolant keep flowing. It stops flowing when I shut it off and that's why the temps go up. It stays cool when driving. Just when I shut it off the temps jump.
