Overheating - Page 2 - JeepForum.com
post #16 of 70 Old 09-16-2013, 08:51 AM
Que89YJ
I agree RP unless the fan clutch fails on. Then it impeads air flow as you increase speed.
Que89YJ is offline
post #17 of 70 Old 09-16-2013, 10:09 AM Thread Starter
cgcarpenter
I agree with both of what you guys are saying but if the radiator was clogged it would still start to heat up on the freeway and slowly Creep up to over heat in stop and go city driving even if the fan clutch was working properly right?
cgcarpenter is offline
post #18 of 70 Old 09-16-2013, 10:15 AM
Rproject
1987 YJ Wrangler
Absolutely. That's what my problem was. I had mud in my fins from a Jeep Jamboree where we were b***s deep in a slough for over 200 yards. Because of the shroud and condenser, I couldn't properly clean the radiator and I couldn't get good air flow. I also think there was a blockage in the system, because after a good flushing, the temps came screaming down.
Put a T cleaning system on your heater core line and flush the system to see what that does. Just make sure you put it on the proper line, the PO of my rig put on a T, but put it on the wrong line. Just one more SMH from my lovely PO.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #19 of 70 Old 09-16-2013, 10:27 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
OP, if you need a shroud i'd be happy to send you my old one for the cost of shipping.
Randonexplosion is offline
post #20 of 70 Old 09-16-2013, 01:05 PM Thread Starter
cgcarpenter
I mean the inside not the outside. The outside looks great. But the flow inside being slightly blocked.
I'm skeptical if flushing the whole system just because its 25 years old and who knows what other problems could come up. It doesn't leak now and I want to try and keep it that way.
And to check the rotation of the pump do I just check which way the fan is turning?
post #21 of 70 Old 09-16-2013, 01:06 PM Thread Starter
cgcarpenter
If you could check shipping that would be great!
post #22 of 70 Old 09-16-2013, 01:13 PM
Rproject
1987 YJ Wrangler
No, the rotation of the pump is dependent upon the impeller blades on the inside of the pump. There's no way, that I know of, to determine rotation from the outside.
On the flushing side, it's not a "HIGH" pressure flush. You're hooking up a garden hose to the T, so you're running 30-50psi water through the system, it's not like you're hooking up a power washer to the system. :-)
1996 White ZJ
Rproject is offline
post #23 of 70 Old 09-16-2013, 02:53 PM
timatoe
timatoe's Avatar
There should be a big "R" stamped on the pump, but you can't always see if with it installed. Some manufacturers put it on the backside of the pump. Although the last one I put on mine had the "R" stamped on an impeller. Depending on where you bought the pump, they may be able to look it up in their system and see which one you got by part number. Easier to try that than pulling it off.
timatoe is offline
post #24 of 70 Old 09-16-2013, 03:30 PM Thread Starter
cgcarpenter
It was installed before my girlfriend bought I'm just trying to fix it. I'll check to see if it has any numbers on the outside
post #25 of 70 Old 09-16-2013, 04:23 PM
Rproject
1987 YJ Wrangler
I remember seeing that R in the impeller of my son's ZJ when we replaced his water pump.
1996 White ZJ
Rproject is offline
post #26 of 70 Old 09-16-2013, 06:27 PM Thread Starter
cgcarpenter
Damn the only thing the I could see on the outside of the pump was it a gmb. It has a few numbers but I couldn't find them anywhere on line. I don't really want to take thing off but I may have too.
I'm thinking of changing the fan clutch cuz it looks old as hell and the flow in the radiator didnt seem very good. And might as well change the tstat.
post #27 of 70 Old 09-16-2013, 09:25 PM
timatoe
timatoe's Avatar
If you're pulling the t-stat, fan and clutch off, just go ahead and pull off the pump and make sure you've got the right one on there. A new gasket is maybe $3.
timatoe is offline
post #28 of 70 Old 09-16-2013, 09:46 PM Thread Starter
cgcarpenter
Yeah I thought that same thing when I got done typing lol
post #29 of 70 Old 09-17-2013, 01:44 PM Thread Starter
cgcarpenter
Somebody mentioned that the fan clutch rotation doesn't matter but they sell both standard rotation and reverse.
The jeep fan spins counter clockwise when looking from the front. Is that reverse rotation?
post #30 of 70 Old 09-17-2013, 01:55 PM
Rproject
1987 YJ Wrangler
If you have a serpentine belt, you have a reverse rotation water pump.
If you have v-belts, you have a standard rotation water pump.
1996 White ZJ
Rproject is offline
