over heating - JeepForum.com
post #1 of 19 Old 04-29-2011, 11:12 PM Thread Starter
sgtrandell101
over heating
My Jeep will over heat when it is idling. Any ideas why? I have flushed and cleaned my radiator
sgtrandell101 is offline
post #2 of 19 Old 04-29-2011, 11:14 PM
jeepinvader
Thermostat stuck closed?
Free Chuck!
jeepinvader is offline
post #3 of 19 Old 04-29-2011, 11:55 PM
moonshinefuel
Could be the fan clutch.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #4 of 19 Old 04-30-2011, 12:04 AM
nembudonna
Times 2, If it was the thermostat stuck closed, it would overheat all the time. But when you flushed the radiator did you also flush the heater core? If not, do it. You won't belive what comes out of there.
nembudonna is offline
post #5 of 19 Old 04-30-2011, 11:07 PM Thread Starter
sgtrandell101
Ya I flushed it or I'm pretty sure I did. My fan is working It could be my thermostat
post #6 of 19 Old 04-30-2011, 11:19 PM
nembudonna
I'am not saying your fans not turning. But is it turning fast enough at an idle? Mine turned, but not fast enough. If it was the themostat, why would it work when you are going fast? How would it know? But it's a cheap try and you probably could use a new one. Get back and let us know. I hate it when people don't get back with what it was. Good Luck
post #7 of 19 Old 04-30-2011, 11:25 PM Thread Starter
sgtrandell101
Ok how could I tell if my fan is turning fast enough?
post #8 of 19 Old 04-30-2011, 11:36 PM
Xpress
Put on a THICK glove and try to stop the fan. If it stops easily, then your fan clutch is gone. If it's difficult to stop, then it's something else.
Xpress is offline
post #9 of 19 Old 04-30-2011, 11:46 PM
nembudonna
You spin the fan with your finger. It should have quite a bit of drag. If your not sure of the drag, pop the hood on another jeep and try it. Or start your jeep and look at your fan and see how fast it's turning at idle and have someone give it some gas and you'll see the Rpm difference. When they let off the gas you should see alot of difference. If not, it's turning to slow. Good Luck
post #10 of 19 Old 04-30-2011, 11:49 PM
nembudonna
WOW, that could hurt. But I've seen guys do it. But then I've seen guys do the either in the tire thing.
post #11 of 19 Old 04-30-2011, 11:50 PM Thread Starter
sgtrandell101
Thanks ill let you guys know
post #12 of 19 Old 05-01-2011, 12:39 AM
Xpress
I don't mean to just SHOVE your hand in there, but gradually try to stop it. It shouldn't stop easily, but if it does, no more clutch.
Xpress is offline
post #13 of 19 Old 05-01-2011, 08:36 AM
nembudonna
I wasn't getting down on you. Some guys do it that way. But when someone told me to do that to check mine, it sounded to crazy. Again, I didn't mean anything.
post #14 of 19 Old 05-01-2011, 10:10 AM
Xpress
Yeah, it sounds crazy enough already. I mean, a heavy metal fan blade, and you're supposed to stick your hand in there while it's turning???
Xpress is offline
post #15 of 19 Old 05-01-2011, 11:13 AM
moonshinefuel
Found a pretty good page on how fan clutches work and trouble shoot for the o.p.
http://www.aa1car.com/library/cooling_fan_clutch.htm
Bow Hunting
