Output shaft oil seal - JeepForum.com
post #1 of 6 Old 03-22-2003, 04:12 PM Thread Starter
Slim
Junior Member
Slim's Avatar
Does anybody know the part number for the output shaft oil seal out of the back of the transfer case. I have gone to the parts house twice and gotten the wrong thing. I have a 94 wrangler with a 6 cylinder motor. Thanks
94' Wrangler Sahara Ed.
Lift,Lockers,& 36's.
Slim is offline
post #2 of 6 Old 03-22-2003, 05:45 PM
BamaJeeper
BamaJeeper's Avatar
You will have to get the model and serial# from the tag on the t-case and go to the dealership. There are different seals for some years of YJ's.
Out of the darkness comes light.
BamaJeeper is offline
post #3 of 6 Old 03-23-2003, 12:06 AM
wiff
wiff's Avatar
this is going to sound messed up but i needed to replace mine and i had the same prob. 3 trips to the parts store and everytime i was given the wrong seal. while standing in the garage scratching my head i looked down at a 4sp tranny i have for my truck that i had just replaced the output shaft seal in. the tranny is out of a 68 or 69 roadrunner its a an 833 4spd the seal looked like the one i pulled of the transfer case so i pulled it out of the tranny to compare, they were identical so i put it in the T-case it fit and sealed fine..go figure, its also the same on a 82 dodge pu with an A-833 tranny(same tranny diferent gearing) hope this helps
wiff is offline
post #4 of 6 Old 03-24-2003, 11:08 AM
jeepers92
np 231 t.c. output seals
I have the same problem as most. Leaky seals hard to stop.
The driveshaft yoke apparently wears enough to keep seals from
sealing. I had my local auto parts store order all seals that it showed for the 231. The one that actually fit the case, leaked because the seal was to large (i.d.). I took the one for the later 231 case (smaller inside dia) and with 80 grit wet/driy paper, sanded the metal part of the seal till it fit in (with the help of a small sledge hammer). It still leaked a little, but after a couple of days seemed to have sealed up. It would be nice is some seal manuf would make a seal for these cases with a smaller dia inside. If you have a set of calipers and can measure your yoke and inside of T.C., a good auto parts store can help.
jeepers92 is offline
post #5 of 6 Old 03-26-2003, 08:20 AM
93 Blue Demon YJ
Had the same problem, bought 2, didnt work...fluid came out everywhere while driving....bought one from quadratec, and it was the right one.
Richard
'93 YJ 4.0 3" RC lift 15x10 wheels and 32" tires.
93 Blue Demon YJ is offline
post #6 of 6 Old 03-26-2003, 12:38 PM Thread Starter
Slim
Junior Member
Slim's Avatar
I finally got the seal I needed I had to go to a local crysler dealer and get it but it worked great. I just don't get how every parts store in town could have the wrong parts on file, its crazy.
Slim is offline
New AA SYE--Now output shaft seal leaking moparjunkee TJ Wrangler Technical Forum 6 07-05-2011 08:46 PM
how do i replace output shaft seal? yjman92 YJ Wrangler Technical Forum 1 09-21-2009 06:56 AM
Replacing t-case rear output shaft seal did I get the right one??? Goobersbro YJ Wrangler Technical Forum 10 06-11-2009 08:19 AM
New seal for output shaft on 231? blacktjsport TJ Wrangler Technical Forum 4 11-30-2006 03:37 PM
Rear output shaft seal peebut YJ Wrangler Technical Forum 4 09-13-2005 09:38 PM
