outboarding shocks - JeepForum.com
post #1 of 7 Old 03-13-2014, 08:32 PM Thread Starter
joker_89yj
outboarding shocks
in the near future i am stretching my yj on a 14 bolt with h1's i want to outboard the shocks for stability. Has anyone done this if so how did you make it work? My main concern is space is this possible with out notching the frame?
joker_89yj is offline
post #2 of 7 Old 03-13-2014, 09:21 PM
baktie_91YJ
Check out pirate 4x4 there's lots of info there
baktie_91YJ is offline
post #3 of 7 Old 03-13-2014, 09:23 PM Thread Starter
joker_89yj
thanks but thats doesn't help me
post #4 of 7 Old 03-13-2014, 10:21 PM
Norcal_chris
Norcal_chris's Avatar
Hundreds have done it.
Google pirate4x4. Yj outboard shocks.
His info helps you a lot.
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
post #5 of 7 Old 03-13-2014, 11:20 PM
fratis
fratis's Avatar
Whether you need to notch or not depends on how wide of a 14 bolt you have and the offset of the H1s. You are just going to have to roll it under and see. You will have options though. Most aftermarket wheels have a smaller offset then the H1s so that could be something to fall back on. You might only need to notch it a little bit. There are also "back half" kits to move the rear frame rails in tighter under the tub.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #6 of 7 Old 03-14-2014, 07:11 AM
Plato2k5
I did it. F250 mounts, Mitch frame, weld. Make sire you have your angle and height correct lol
Plato2k5 is offline
post #7 of 7 Old 03-14-2014, 08:56 AM
yjcrawlr
I did mine with the ford towers as well. Ive had 3 different sets of rims on my yj. With the first set of rims the tires would barely rub the shock body at full flex on the passenger side. It could have been fixed by notching the frame, bumpstop adjustment, or different rims. I just changed my rims because I wasn't a big fan of the fake beadlocks anyway. My guess is with H2s you will rub if you dont sink the towers into the frame a little.
90 YJ 102 in wb stretch, SOA, dana 60, 14 bolt welded,4.56s, 37in Parnelli jones dirt grips, currie twin stick dana 300, york oba, tractor link traction bar, full custom armor,poison spyder tube fenders, 95Cherokee High Output 4.0
2014 JKU, modified Rubicon Rails, RC stubby with warn 8000m, 2" leveling springs and OME trim spacers, Superchips Flashcal, Spidertrax wheel spacers, rubi shocks, and Lots more mods soon!!!
yjcrawlr is offline
