Original wiring and 350 swap - JeepForum.com
post #1 of 5 Old 06-02-2010, 08:42 AM Thread Starter
madjeep1
I have a 1988 Yj and I am dropping in a 1995 TBI 350. I decided to go with a "Painless" wiring harness. I have all the sensors and computer hooked up. The only things left is connect the 12V and ignition for the computer. My problem is the original wiring had a small silver solenoid on the firewall. It has different "posts" labeled battery,ignition, sol, egr,and ground. There is about five wires coming from the fuse block going to the battery "post" and there was a wire coming from the battery to that solenoid. Now that the GM stater has its on solenoid and I am not using EGR can I do away with that firewall solenoid. From what I am thinking is I can use a relay because all I need is constant 12V and swicthed ingition power. Am I correct?
Also what needs to be done about wiring up the Alternator? Do I need to run a cable from the battery to the starter and the back of the alternator and one to power the fuse block?
Hope someone can point me in the right direction. Thanks in advance
madjeep1 is offline
post #2 of 5 Old 06-02-2010, 10:05 AM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
I would find out how the 1995 SBC was wired up in the car/truck it came from. Then you need to mimic that wiring in the YJ.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 5 Old 06-02-2010, 10:15 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
Things like fuel pump replacement needs to be addressed also. I suggest doing a search on the 'net for answers and check out this link also here in JF. There may be other here in JF also.
http://www.jeepforum.com/forum/f12/s...derway-324622/
post #4 of 5 Old 06-02-2010, 05:08 PM Thread Starter
madjeep1
Before the swap I had the 258 with the "junkyard" tbi on it. So I already had a fuel pump installed that would work with the 350.
I just wanted to know if I could do away with the solenoid and how to wire the Alternator up? Has anyone done this before and what did they do? Can I just use a relay for the 12V and switched ignition power. Thanks
madjeep1 is offline
post #5 of 5 Old 06-02-2010, 07:56 PM
jeeptim
Yes. do away with the solenoid on the firewall. The battery cable should go from the battery to the large stud on the starter, then relay a smaller gauge wire (8-10 ga) from the large post on the starter to the stud on the back of the alternator. You will want to extend the small wire that was on the solenoid on the firewall (ignition) and run it to the small stud on the back of the new starter. (unless your new wiring harness included that wire) You can run another 10 ga from the back of the alternator to the fuse block. You will want the computer to be on the igniton switch source. good Luck.
On a side note do not forget to run the battery ground straight to the block, then run a ground strap from the block to the frame.
1989 Islander 4.2 Automatic. RC 2.5" lift. 265/75/16
jeeptim is offline
4.0L swap - wiring help Dingleberry YJ Wrangler Technical Forum 6 09-07-2011 01:08 PM
5.9 swap wiring antec TJ Wrangler Technical Forum 10 05-28-2010 11:18 PM
2.5L to 4.0L swap: Wiring 101 Tomb Raider YJ Wrangler Technical Forum 17 09-30-2009 10:48 PM
4.2 swap to OBD2 4.0 & ECM was specific to original 4.0 jeep Evdog89 YJ Wrangler Technical Forum 6 03-27-2009 11:18 AM
4.0 swap wiring thewoodscrew YJ Wrangler Technical Forum 0 01-04-2003 03:25 AM
