optima battery - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > optima battery
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 03-28-2002, 12:55 PM   #1
Jeepguy3401
optima battery
I just replaced my junky old battery with an optima red top. The battery holder isn't quite wide enough for the battery. Is there any way to secure your battery short of a bungee? The holder works all right to hold it down just can't tighten it down all the way, so the battery is a tad loose, not enough to rattle or bounce though. Is it even worth messing with the thing since it doesn't rattle or bounce? Thanks.
'87 YJ,4.2L 6cyl(rebuilding someday) On 33" Mickey Thompson Baja Claws, (unlifted, but big lift in store, when I get some $$$)upgraded clutch and brakes, broken loud stereo.(Can't imagine how that....COUGH!..WATER....happened. Haven't used a top doors or windshield in uh,.....hmm.... since midwinter? That sounds right.
Jeepguy3401 is offline   Reply With Quote Quick reply to this message
Unread 03-28-2002, 04:25 PM   #2
Skeeter
Although that is a sealed battery I would stop it from bouncing around. I have the same battery in my YJ and it went right in with no problems. You can bye a new holder for the battery or bye shorter J clamps to hold it down. Try marine supply stores. They usually have heavy duty battery trays or clamps that will work with your setup. Hope that helps ya
Skeeter is offline   Reply With Quote Quick reply to this message
Unread 03-30-2002, 12:23 PM   #3
Jeepguy3401
Thanks, I'll try that. By the way, I got the new battery and a new flywheel kit installed, and now it runs like a beast! Now, if I could just get some newpiston rings in there......
