Optima battery - Page 2 - JeepForum.com
post #16 of 20 Old 10-09-2011, 04:22 PM
92 Green YJ
92 Green YJ's Avatar
Well one thing worth knowing is if you have a winch hooked up to a red top the warranty is gone instantly. They don't cover red tops if you run a winch period! Only the yellow tops are covered under warranty for winching.
That being said their quality has gone down. But my current one is still working well for me
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #17 of 20 Old 10-23-2011, 01:13 PM
OptimaBill
HI zte87,
As mentioned before, if you are going to use a winch on your vehicle, I would suggest the YellowTop. It is a dual purpose design that will start the vehicle and also works fine for deep-cycle applications.
Xpress is correct regarding the volume of our batteries in use today, versus other brands and that does lead to a lot of conversations about them. Here is a link to just that and reviews about different batteries on this site. As 92 Green YJ mentioned, RedTops are not designed or warrantied for deep-cylcle use, including winches. YellowTops don't need to be drained and recharged periodically to maintain health and the quality of our batteries has never been better. In fact, keeping batteries fully-charged is really the key to extending battery life, regardless of the battery you are using.
On a personal note, a friend of mine had a YellowTop that was so deeply-discharged this week, it did not register with a volt meter. He tried charging it with his shop charger and just wasn't getting anything. I brought it to my shop, placed it on a low amperage microprocessor charger and within 24 hours the battery has 13.13 volts in it. I just checked the battery this morning.
There is a lot of misinformation out there about recharging our batteries but the truth is, if you will follow our instructions on recharging it is amazing how many batteries are recoverable. Many of the “bad” batteries returned to us now are just deeply-discharged and work fine, once recharged.
If I can answer any other questions about our products, feel free to pm or post here,
Thanks,
Bill Howell
eCare Manager, OPTIMA Batteries, Inc.
OptimaBill is offline
post #18 of 20 Old 10-23-2011, 01:46 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Thanks for posting, Bill. There are a lot of guys running optima's in their jeeps and could use some help answering questions on this board. Would you go ahead and sign up as a vendor so we can have some alternate ways of contacting you?
Thanks!
Luck Favours The Prepared
Anticanman is offline
post #19 of 20 Old 10-23-2011, 04:54 PM
JakeMurray24
I have a blue top in my jeep, its worked amazing for 3 years, no problems
1989 YJ Candy apple Green, D30front, 8.8rear, 4:10's, Lock right front, 4"RC springs rear, 3.5"BDS springs front, SYE with double cardian shaft custom made, home made rockers, 33" goodyear mtr/k, smittybilt stinger, home made light bar, marine stereo, cobreau baja jp seats
JakeMurray24 is offline
post #20 of 20 Old 10-23-2011, 05:06 PM
mazyj
Ive had similar experiences with many batteries which appeared to be dead so absolutely believe this to be true. Simply finding a way to get some current running through them got them working again in a few hours. That being said I have a Diehard P4, haven't had a single issue with it, holds its charge great, and I love the dual terminals. I have no experience with Optima's other than internet banter.
91 wrangler 4.0L, 4 in Suspension lift, 1 inch Shackle Lift, 1 inch Body Lift, 35" BFG Mud Terrains, Warn Rockcrawler Front Bumper, Hand Throttle, HiLift, 12 pack of Natty Boh.
mazyj is offline
