Opinions wanted: Need help deciding on a lift - JeepForum.com
post #1 of 2 Old 06-05-2001, 12:59 PM Thread Starter
jobob
Okay, I am at a dilemna. I am planning to lift my 90 yj. I thought I had decided on the RE 4.5" extreme duty, It seemed to be the most complete kit for a SU configuration. Then I happened to find a 5" kit from Full-Traction Suspension, which is actually 3" springs and a 2" shackle reversal lift. It also seems to be complete, and the price is only a few dollars more than the RE kit. So my question is for opinions regarding my application. Which do you think would be better? My jeep is a daily driver, and I hope to attend a good trail ride at least once a month. I am planning on 33" tires.
Thanks in advance for your help!
Thanks for the help.
jobob
jobob is offline
post #2 of 2 Old 06-05-2001, 01:38 PM
rayray
rayray's Avatar
Personally, I would stick to the RE kit. Also, keep in mind the issues with a SRS kit. First, a 2" lift sounds a bit high. Also, that's 2"'s to the front. You still have to level out the rear. Additionally, when you do a SRS, you change the articulation angle. No longer does the axle travle up and down, it moves at an angle that loves to eat your fender wells. Now, in defense of SRS (I use them), they do reduce the amount of shock that travles through the rig. Which results in a lot less wheel hop. So, you take the good with the bad. The fender problem is nothing a little metal trimming won't fix.
For your application, I would still go with the RE kit.
Earth First! We can wheel the other planets later
rayray
rayray is offline
lift opinions wanted richchs62 YJ Wrangler Technical Forum 17 08-04-2007 08:38 AM
opinions wanted Tulsachokehold YJ Wrangler Technical Forum 0 03-23-2007 10:06 AM
Opinions Wanted on this Lift Kit paintguy YJ Wrangler Technical Forum 5 03-06-2007 05:04 PM
opinions wanted 78cj7401ci YJ Wrangler Technical Forum 2 09-11-2006 12:14 PM
opinions wanted djab TJ Wrangler Technical Forum 17 12-09-2004 12:19 AM
