Opinions on This Rad? 1995 YJ 2.5 - JeepForum.com
post #1 of 4 Old 03-10-2013, 01:17 PM Thread Starter
taylor797
My rad is on its way out and I'm looking at replacing it with something better than stock. Does this one look good? Seems like a good price with the fan, would you think it would be enough to get rid of the stock fan and wire this one in? http://www.ebay.com/itm/2-ROW-FULL-A...25bb22&vxp=mtr
Thanks in advance
taylor797 is offline
post #2 of 4 Old 03-10-2013, 03:54 PM
jsawduste
2006 YJ Wrangler
Thanks in advance
You can buy it but it would be a step down from stock.
Most folks think the multi core (or row) aluminum radiators are the so much better then stock.
How many years did your stock one last ? Did you know that the stock fan and clutch pushes with the shroud flows over 4000 CFM ?
The one you show has a 2300 or so CFM fan that only covers a small p[portion of the radiator. Leaving a good percentage untouched to pull air through.
Take your stock factory radiator to a shop and have it cleaned and rebuilt. Freshen up the fan clutch if need be. Then drive it for another 20 years.
jsawduste is offline
post #3 of 4 Old 03-10-2013, 05:31 PM
SeanB95YJ
rather than the one on E-bay, I'd suggest one of these.... http://www.championradiators.com/jee...radiator-87-06
and head to a junk yard and get yourself a fan from a Taurus, Thunderbird, Mark VII/VIII or Volvo.... those (well, at least the Ford ones) the built-in shroud is just about an exact fit for the YJ rad.
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #4 of 4 Old 03-10-2013, 06:01 PM Thread Starter
taylor797
Thank you very much for the info
