Opinions Please 5.3 SBC - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Opinions Please 5.3 SBC
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 05-14-2014, 11:50 AM   #1
nzpete
I've been offered a 2003 SBC 5.3 engine with wiring harness/computer, but minus the alternator and PS pump. The guy wants 700 bucks for the whole setup and that appears, to me, to be a great deal. Any issues, pro or con, with this year model? Suggestions?
It is going to go into my 95 YJ.
To me, RC is kind of the Harbor Freight of springs. Sometimes you get a good deal and sometimes you don't.
nzpete is offline   Reply With Quote
Unread 05-14-2014, 01:54 PM   #2
Jeepsr4me
what trans you gonna use? And yes that 5.3 is GREAT....
Jeepsr4me is offline   Reply With Quote
Unread 05-14-2014, 02:28 PM   #3
nzpete
I picked up an SM465 for 50 bucks last weekend and plan on doing a rebuild. I will, most likely, buy an adapter to mate up the 231.
Unread 05-14-2014, 02:35 PM   #4
yjcrawlr
You are looking at a $627 kit to adapt a ls motor to sm465!
90 YJ 102 in wb stretch, SOA, dana 60, 14 bolt welded,4.56s, 37in Parnelli jones dirt grips, currie twin stick dana 300, york oba, tractor link traction bar, full custom armor,poison spyder tube fenders, 95Cherokee High Output 4.0
2014 JKU, modified Rubicon Rails, RC stubby with warn 8000m, 2" leveling springs and OME trim spacers, Superchips Flashcal, Spidertrax wheel spacers, rubi shocks, and Lots more mods soon!!!
yjcrawlr is offline   Reply With Quote
Unread 05-14-2014, 02:59 PM   #5
nzpete
Yes, I see the kit cost.
Unread 05-14-2014, 04:16 PM   #6
Randonexplosion
Trailer Queen
Randonexplosion's Avatar
The only drawback I see for that year of engine is that the throttle body is Drive by Wire. But some people prefer that over cable. You can always swap it out to a DBC if you want to. Are you dead set on staying manual? I love my 4l60e.
5.3/4l60e swap
August YJOTM
Exiled Offroad - Colorado
Randonexplosion is online now   Reply With Quote
Unread 05-14-2014, 05:53 PM   #7
nzpete
I'm not put of by DBW, but will most likely do what is easier or most cost effective.
I'm not averse to an automatic, and wouldn't mind the opportunity to pick one up and rebuild it for the experience, but I have the SM465 already.
Unread 05-14-2014, 05:55 PM   #8
Jeepsr4me
Auto for the win...... That manual you got is more than strong enough. But for some hard mountain trails were you got to just lay into it to get to top, you dont want to be shifting..
Unread 05-14-2014, 06:40 PM   #9
YJ4LIFE
Early ones have cold start piston slap due to centered wrist pin (I think my 2002 tahoe does). Later Gen 3's have them offset. check ls2.com ls1tech.com they use to be big boards, not sure if they are anymore. Also intake manifold seals and knock sensors are also an issue. Do searching before you button everything up so you dont have to do it twice.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline   Reply With Quote
Unread 05-14-2014, 06:52 PM   #10
panaceabeachbum
panaceabeachbum's Avatar
I like the DBW. The 4l60 seems to be a great trans, breeze to rebuild
panaceabeachbum is offline   Reply With Quote
Unread 05-14-2014, 07:23 PM   #11
rykemc
On the 5.3 motors, stay away from the newer body style GM 5.3 motors. 07 and up. They are junk compared to the earlier 5.3.
My Jeep build. :)
http://www.jeepforum.com/forum/f12/m...build-1502848/
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline   Reply With Quote
Unread 05-14-2014, 07:56 PM   #12
Randonexplosion
Trailer Queen
Good to know what my noise is. Goes away after 15-20 seconds. Never did it in the donor. My girlfriends 03 Tahoe doesn't do it and it has more miles than mine.
5.3/4l60e swap
August YJOTM
Unread 05-15-2014, 05:56 AM   #13
nzpete
Thanks. I did a bit of research and it seems to be a widespread issue, and not limited to the 5.3 of any year group or even manufacturer. For 700 bucks with the wiring harness, and computer, I will probably go ahead and buy it.
Thanks, too, for those that suggested the automatic. I've always been a manual shiftin' kind of dude, but I just might opt for a used automatic and then rebuild.
Unread 05-15-2014, 06:30 AM   #14
Chrisnvegas
The 5.3?
It's a GREAT motor.
This magazine bought a used one with 160,000 miles, hooked it to a dyno, installed twin turbos just to see how much it could handle before bowing up.
After 70 dyno "runs" - 6300 rpms, 24 lbs of boost, they hit 1308 horsepower! On an old motor!
They were not able to "blow" it up, a lifter collapsed. They replaced the lifter and pushrod and it fired right up.
http://www.truckinweb.com/tech/engin...mm_turbos.html
What did you want to know?
Do not write in this area, for office use only.
Chrisnvegas is offline   Reply With Quote
Unread 05-16-2014, 05:38 PM   #15
nzpete
Okay, couldn't let the deal go, so I picked up the 5.3 complete with harness and computer. It came out of a 2003 Silverado and looks to be in very good shape. The truck it was pulled from had 80,000 miles on it.
I'm going to start cleaning it up and weld up a run stand so that I can make sure there are no issues. I have the SM465 for it, but after some of the comments, I'm seriously considering an automatic. It seems like an auto would be an easier swap. True?
