Operating temperature of chevy 350 conversion
#1 | |
Hello all, I am the proud owner of a 1989 yj that was converted to a chevy 350 small block by the previous owner. On my last wheeling trip the temp guage climbed from the "normal operating temp" of 180 to around 200 to 205. I since have replaced the thermostat, had the radiator flushed, replaced the water pump, checked head compression and replaced the radiator cap. The temp now stays steady at around 200 degrees. I originally bought the jeep in oct in a cold climate and now the weather is warming up could this have something to do with the temp fluctuation? Am I just worrying about nothing or could there be something that I am missing? Thanks in advance for replies.
Dave
#2 |
XJ on 37's
if it has a 195 t/stat, it would sit at around 200-205 when upto temp on a trail.
sounds fine to me martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee.... 1998 Range Rover 4.6 HSE 2000 4.7 4WD WJ with a rebuilt motor. 4.3/700r4/new frame buildup (YJ).... http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/ Years to gain the hands on experience, and offer it freely. Minutes to gain the knowledge from the internet, and quote it just as freely. Choose wisely! |
#3 |
TrailWorthyFab.com
What kind of a radiator are you running? Might want to look into a large aluminum radiator. Money well spent. x2 on Martin's thought. 200 isn't all that hot. I wouldn't sweat it but if you want to lower it what I have listed above is your best bet.
Just a simple mans thinking. Todd
BUY IT DONT' BUILD IT!! You will be money and time ahead. (Flip off) |
#4 |
I am running an aluminum race radiator with seperate tranny cooler and the thermostat is a 185. If you all think 200 isn't hot I'll concentrate on some other upgrades it needs instead. Thanks for the info. Dave
#5 |
on really hot days on the trail mine has got to 210. swap a fan in with a full shroud for better cooling if you like but it sounds fine.
"We'll get out of this disaster in time for the next one" "I'm done recomboobulating the energy-mo-tron" 88 YJ, 350/350 Chevy, Twin Stick Dana 300 with JB 32 spline rear output, 6.5" lift, Front Scout II Dana 44 w/Yukon 4340 shafts, trac loc, 4.27's, Warn Premium Hubs, flipped YJ Tie Rod, Ford F150 front calipers, Rear Scout II Dana 44 w/Alloy 4340 shafts, HD RPT retainer plates, 4.27's True trac, Steeltech Disc brakes, Cage upgrade, B&M Prostick Shifter, Custom Fabbed tire, gas, jack carrier, 3/8 angle rear bumper, clevis's all around, old & reliable rep8000 winch. Flood lights. loud stereo. 35x12.50 swampers and a bunch of other stuff |
#6 |
in my stock heavy duty chevy p/u there is a 175* thermostat. just wanna let you know its a GM thing and it came stock in my motor (it is a heavy duty truck tho)
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
