Operating temperature - JeepForum.com
post #1 of 5 Old 03-27-2002, 12:39 PM Thread Starter
Dunny
Can't seem to find anywhere that tells the
correct engine operating temp for a 4cyl
95. Anyone know? thanks.
'95 YJ 2.5L Hardtop 30" rubber
grill guard; 5spd tranny
Dunny is offline
post #2 of 5 Old 03-27-2002, 01:40 PM
V8wrangler_idaho
it dosen't really matter to much on the temp. You just want it to get to above 180. anything below and the engin will rust on the inside. best running temps would be from 180-about 240 once you get above 240 your getting close to the boiling point. But you can get a higher pressure radiator cap and you or ok. but anywhere between 180-240
Daniel Mclay
93 wrangler 8 inch SOA SRS suspention lift 35/12.50 Mt. efi 350 700r4 tranny np 205 t case dana 44s front and rear. lots of extras.
V8wrangler_idaho is offline
post #3 of 5 Old 03-28-2002, 08:56 AM
PoorFool
I'm not sure about that. I always thought my '94 was running cool, so I changed the thermostat. The parts manual says the factory recommendation was something like 160. Still not sure, I checked the sending unit out and it's fine. Probably should have called the dealer, but figured it was better to be a little cool than too hot. It runs fine, and the heater worked well this winter (first winter with it). The rust issue seems valid though. Your best bet is to call a Jeep service department.
Turbocharged 4.0, 35" Kevlars, 33 spline Detroit D44, 4.88s, heavy foot.
PoorFool is offline
post #4 of 5 Old 03-28-2002, 03:12 PM
89JEEPNYC
89JEEPNYC's Avatar
Hey as long as it's not over heating don't worry!
89JEEPNYC is offline
post #5 of 5 Old 03-28-2002, 09:06 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Normal operating temp of any automobile motor is about 185 to 220 (unless they changed the rules on me!)
4wheeler4CJ is offline
chevy 350 tbi operating temperature jeep350chevy YJ Wrangler Technical Forum 32 05-09-2009 07:22 PM
Normal operating temperature? hunter44102 TJ Wrangler Technical Forum 2 07-31-2007 09:07 AM
4.0L Optimal Operating Temperature FlatsCrawler YJ Wrangler Technical Forum 6 06-17-2007 09:41 PM
Normal operating temperature? Achped TJ Wrangler Technical Forum 16 02-10-2006 04:51 PM
Normal operating temperature? reactor YJ Wrangler Technical Forum 4 12-02-2003 02:34 PM
