Only high beams work! - JeepForum.com
post #1 of 15 Old 09-29-2010, 06:57 AM Thread Starter
92yjwrangler
I tried new headlights and now i need to replace the switch in the dash. I went to advanced and they didnt have anything called a multifunction switch only a blinker hazard wiper switch but the brights are on the same switch right? this is what it looks like
Auto Parts Deal
is that the right part that i need to fix it?
92 wrangler yj 33in Dunlop Mud Tires
pioneer head unit and front speakers sony amp with 2 rear 6x9 alpine pro series speakers
92yjwrangler is offline
post #2 of 15 Old 09-29-2010, 04:26 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Auto Parts Deal
This is the one you want I beleive;It may be a dealer item also #5600 3119
Original Replacement Parts 56003119 - Headlight On/Off Switch for 87-95 Jeep® Wrangler YJ - Quadratec
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 15 Old 09-29-2010, 04:33 PM
idaholtby
I believe the OP is inquiring about the Hi/Low switch on the column, not the headlamp switch itself. One other question for clarification... Is this a Canada built model with DRL?
idaholtby is offline
post #4 of 15 Old 09-29-2010, 04:37 PM
mdubs
No, they are not on the same switch.
I had this problem for a bit and I can only explain it for now but I will get some pictures for you sometime tonight.
There is a rod that runs along the left side of the steering column that controls your brights. It is actuated when you pull the "multi function switch" lever toward you. Unfortunately, this rod is not positively engaged by the multi function switch; There is a plastic piece that goes between the rod and the switch and if it isn't placed exactly right, it won't work.
I had the exact same problem on mine.
The temporary solution is to remove the plastic cover that is just down the column from the multi function switch lever (it is a complete PITA to remove) and find the rod that I am referring to. push that rod along the axis of the column and let it return. Your brights should turn off.
Like I said, I will get some pictures of what I am talking about tonight and update this post with those.
mdubs is offline
post #5 of 15 Old 09-29-2010, 06:39 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Auto Parts Deal
That is for your turn signals. For the headlamp dimmer switch the part # is 5600 3406
post #6 of 15 Old 09-29-2010, 08:16 PM
Tigger87
1987 YJ Wrangler
Ok, not to steal this post, however I have the opposite problem. I pull back on the multi function switch and there is no click, nothing. It pulls back and nothing happens. So I am stuck with low beams. Am I in the same boat as far as the rod not being activated. The PO has already pulled the side of the column off for me and looks like they installed an after market switch on it. Thanks.
Tigger87 is offline
post #7 of 15 Old 09-29-2010, 09:06 PM Thread Starter
92yjwrangler
If i switch the multifunction switch it clicks and goes to the low beam setting but my lights just turn off and the parking lights and tail lights stay on if i switch it again my high beams come on. so i think the rod is good but im not sure? could it be the head light dimmer switch or the headlight on off switch?
post #8 of 15 Old 09-30-2010, 09:44 AM
mdubs
Ok, it sounds like you have an electrical issue. Your brights can't turn on without the dash switch being good as far as I know. Time to break out the multi-meter and start checking wires
Here's a pic of the rod just because I had already taken it. It is the rod with two bends that you can see just behind the wires.
and a link to the pic if this doesn't show up:
Picasa Web Albums - Mike W
@Tigger87, if this is what yours looks like then just push that rod down along the axis of the column and it should turn your brights on. If you don't have this....
I was only able to get this one last night because I was crunched for time. If anyone still wants a pic of the little plastic piece that I referred to earlier, I will get that today.
HTH
mdubs is offline
post #9 of 15 Old 09-30-2010, 09:46 AM
schaef89
its the dimmer switch for sure. my brother just had to replace his on his 90 yj. He only had his brights no low beams
schaef89 is offline
post #10 of 15 Old 09-30-2010, 01:14 PM
Tigger87
1987 YJ Wrangler
HTH
Ok, I checked it last night and got it working. I have to push on the metal rod but they at least work. There does not seem to be a way to mount the rod to the switch for it to work. I am guessing I am missing a mount. I am thinking of just relocating the switch to a floor button like Ford uses anyway. Unless there is an easy fix for this. Thanks.... glad to have the high beams.
Tigger87 is offline
post #11 of 15 Old 09-30-2010, 01:24 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Isn't the switch adjustable? You can loosen the screws holding it to the column and slide it up and down can't you?
post #12 of 15 Old 09-30-2010, 02:31 PM
Opihi59
from here it gets rough
Opihi59's Avatar
In case you need to tear into your steering column to work this out, you will find these 2 links helpful.
Tilt Column Fix - Dale's Jeep Junk
http://www.fiero.nl/forum/Forum2/HTML/088020.html
Many good photos, and step by step. Some of the tools can be "rented" from car parts places for a returnable deposit, like the lockplate spring compressor, or you can make one easily enough.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is online now
post #13 of 15 Old 09-30-2010, 03:23 PM
mdubs
This one shows the "High Beam Follower". The little plastic dealy that I was referring to. You can see by comparing my photo to his that I don't have mine installed at the moment
It kept falling out when I was putting the column back together and it P'ed me off enough that I just left it out. I guess I'll have to fix it before I go for my safety inspection later on in the year...
mdubs is offline
post #14 of 15 Old 09-30-2010, 04:14 PM
Opihi59
Opihi59's Avatar
I'm not sure what you used before for a lockplate spring compressor, but I made my own........
http://www.jeepforum.com/forum/f12/l...ressor-508587/
post #15 of 15 Old 09-30-2010, 04:21 PM
monkeyhouse
Auto Parts Deal
I wonder if you might be missing a part from the column. I had the same issue you had one night, but it disappeared the next night. If you've ever read my post when I took my column apart, I am missing an essential part, it is pictured in Dale's writeup though. It's a small clip behind the lockplate.
First Jeep was an 1989 YJ, I've also had a Grand Cherokee. Currently, I have a 99 XJ.
monkeyhouse is offline
Low Beams Work but High Beams do not AmyAmy TJ Wrangler Technical Forum 3 12-08-2011 08:39 PM
Headlights flicker and die, high beams work chojin1980 YJ Wrangler Technical Forum 5 12-07-2009 04:11 PM
one headlight out, but high beams work fish4life TJ Wrangler Technical Forum 5 11-15-2009 09:01 PM
high beams work but won't stay on blamejane2 YJ Wrangler Technical Forum 13 10-22-2008 11:35 PM
High beams dont work jeepin92yj YJ Wrangler Technical Forum 2 11-08-2007 12:43 AM
