Only have 4th gear AX15 - JeepForum.com
post #1 of 1 Old 08-25-2010, 05:29 PM Thread Starter
jeeping68
1978 CJ7
My wife was cruising along on the freeway in 5th gear when the engine starting revving up and the Jeep started slowing down. She pulled over and couldn't get the Jeep to go anywhere. Upon further messing around, we discovered that she has no gears except 4th gear. In addition, you can switch the gears to any other gear except for 4th without the clutch. This includes reverse. Fourth gear works just fine. You can push the clutch in and as long as you feather the clutch and give it enough gas, you can get it moving. This is a 93 Wrangler with the AX15 transmission. Any ideas anyone?
jeeping68 is offline
ax15 , transmission
AX15 Lost First Gear GunnerJK TJ Wrangler Technical Forum 5 01-05-2010 04:16 PM
Ax15 grinding going into 5th gear Why J? YJ Wrangler Technical Forum 19 12-13-2009 03:23 PM
87- 90 AX15 What gear oil are you using? Alabamaranger YJ Wrangler Technical Forum 15 01-03-2008 05:59 PM
AX15 gear oil question rce YJ Wrangler Technical Forum 2 09-22-2004 10:45 AM
AX15 won't go in gear 89YJmoneypit YJ Wrangler Technical Forum 14 09-21-2003 09:17 AM
