ONE MORE TIME PLEASE! tiresize/axle ratio?? - JeepForum.com
post #1 of 7 Old 06-04-2011, 08:52 PM Thread Starter
lincolnmatthews
2015 JK Wrangler
I know this has been covered a million times, but wanted to check with you guys, so many knowledgeable guys here! I have an 87 that is getting a BDS 2" lift going with 31" tires. I am thinking about going with a 3.73 gears is this going to be ok with my tires?, or should I go with 4.10's?. I thought with my stock axles that I couldn"t go with more than 3.73's?. Then I want to go with some kind of a front locker only, I know the about the axle limitations with these years. What would you guys recommend?, am I right in putting a locker up front?. I should note I have the manual trans with the 6 banger! Which locker is more trouble free? I dont think I want air or electric, how about the one that uses the cable style?? Sorry about all the questions, maybe this will finally put this issue to rest? Thanks for any help
lincolnmatthews is offline
post #2 of 7 Old 06-04-2011, 08:55 PM
TheNewbie
Regearign is expensive. It wold be cheaper to find some 4.10 axles from a 4 banger YJ with the AX5.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #3 of 7 Old 06-04-2011, 11:12 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
You shouldn't need to re gear with those. I'm on 30's and I'm fine. And you're right about the locker in the front.
Michaelgoesrawr is offline
post #4 of 7 Old 06-05-2011, 02:50 AM
92XJT
I would go this route as well if you wanted lower gears. I picked up a set for $100 on ebay a few years back.
92XJT is offline
post #5 of 7 Old 06-05-2011, 06:59 AM
linusb
I ran 32's with 3.07's and it was fine...sluggish...but fine.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #6 of 7 Old 06-05-2011, 07:10 AM
Noltz
YJ Wrangler
You're asking the right questions, so no apologies needed
1) You've got 3.07's in a 4.2/Manual combo. I drove mine with 33's and it was okay, although 5th gear was only good above 60mph and cool weather (no joke). If you're going to swap axles, get the 4.10's. You can live with a few more RPM's on the highway for the better ratios for around town. The 4.2 is a bit of a dog with it's amazing 120hp so you want to keep it geared high anyway.
2) Lockers are completely a personal decision. Auto 'lunchbox' lockers are reasonably priced and with the vacuum disconnect you won't suffer on the street. I've not seen a cable-type locker. Are you thinking about the cable disconnnect systems (also called "posi-lock")? These aren't lockers, they're cable driven replacements for the trouble-prone vacuum disconnect system. ARB is an air locker, and I've seen electric lockers too (can't think of name).
Swapping a D35 back into your Jeep is very simple, but you're missing an opertunity to get a much stronger axle for just a little more money. Search for "Ford 8.8 YJ swap"... there's hundreds of examples. The Ford 8.8 can be found in 3.55, 3.73 and 4.10 ratios, and many came with limited slip diffs, factory! Not as good as a true locker but way better than open and easier on the street! It's not a bolt-in, but read about it and make your own decisions.
Personally, I've found a D30 with 4.10's for my front, and will get a disc-brake equipped, Ford 8.8 shortly with 4.10's too. This is for my 4L Auto YJ running 35" tires.
EDIT; I just realized I didn't mention I had a 4.0 head swap too. I did not drive it with the stock head as it was cracked, a 4.0 swap was a no brainer.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline
post #7 of 7 Old 06-05-2011, 01:42 PM
Michaelgoesrawr
Ox lockers are cable actuated.
The 4.10's would be good. And if you've got the extra cash and can weld then get the 8.8.
tiresize sjfay JK Wrangler Technical Forum 6 05-23-2008 07:45 AM
Axle ratio help mstout JK Wrangler Technical Forum 16 08-20-2007 12:05 PM
Sahara - Axle locker? Axle ratio? Meir10 JK Wrangler Technical Forum 8 02-25-2007 02:15 PM
3.07 axle Ratio & D44 jameskjeep TJ Wrangler Technical Forum 14 03-07-2006 09:57 PM
Axle ratio ? Mike5150 TJ Wrangler Technical Forum 4 02-11-2006 10:01 PM
